Star+ & Star One for Viewsat Ultra
Username: Rohinivikas
Post Number: 106
I was getting Star+ & Star One. After uploading the latest file, i am getting all the channels except Star+ & Star One.
Can someone please help?
Username: Cartier1
Post Number: 1836
rescan
Post Number: 107
I forgot how to do a channel scan. I don't want to rescan the whole satelite. Can you tell me how to do channel scan only for Star+ and Star One
Username: Cartier1
Post Number: 1837
u should do some f%ucking reading . u wanna juust watch and do nothing ., my grand ma knows how to scan . it's your home work do it or die. also when u scan it take secondes. dont answer me bye
Username: Kocsuckercartier
Post Number: 27
JUST FU-K OFF CARTIER <GO BLOW A CAMEL
Username: Desisatguru
hahahahaha,,,huuuuuuuuuu,hoooooooo,heeeeeee,,,anyways,goto xxx.lyngsat,com/echo3ku/html(IF U ON 61-5)
look for tp number or downfreq for srat+ and 1,and then scan those tps.
Username: Cartier1
Post Number: 1838
savior ok im going to fu&ck off a camel. ask your sister to come to me tonight. i know she missed my big you knwo what i mean. miss sadscanner
Post Number: 108
I did the rescan but still i am getting autoroll processing for Star+ & Star One
Username: Cartier1
Post Number: 1840
ok star+ echo3 tp 12326 20000 H 5/6
satr1 echo3 tp 12414 20000 H 3/4
Username: Kirankumar
NO Bashing
Post Number: 2704
if you are on 61.5
write down antenna settings
do factory reset
do hard reboot
adjust antenna setting
do auto scan
do not do blind scan on vs ultra
Post Number: 109
Dear African
I did the factory default and then did the auto scan on 61.5, 110 & 119.
I am getting all the channels. I got Star1 and Video Italia on 716 & 718. Star One came for 1 sec and now it again showing me autoroll processing for Star One and Video Italia
These channels used come on 4006 & 4007
Can you please help?
Username: Jurj1
Post Number: 564
Cartier is a sandnigga . aka mussawell,aka yannis and more ! he blows camels for a living.
Post Number: 110
Dear African
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2160
African with 2 or 3 last bin we can do a blind scan without any problems on Viewsat and no double channels.
Blind scan recover all Tp lost and correct polarisations problems.
Remember it my friend
Post Number: 111
Mr. Plymouth, do you want me to blind scan. Is it going to do to a blind scan on 110, 119 & 61.5. Is there any way i can do a blind scan on 61.5 only
Username: Cartier1
Post Number: 1842
VIKAS U ARE NOT GONNA SOLVE UR PROBLEM ICF U DONT LISTEN'. FIRST LISTEN.
DO U CHECK IF THE TPO'S I GAVE U SAME AS YOU HAVE WHEN U SCAN THE ECHO 3. ARE THEY SAME TP'S????????????
THIS IS NUMBER ONE . NUMBER 2 MAKE SURE OF UR LNB IS SAME AS IN YOUR CONFIGURATION OK
Post Number: 112
Dear Sir
Everything is same. I was getting StarOne and StarPlus. After loading the new bin, i am getting autoroll processing on star one & star plus channel.
Username: Cartier1
Post Number: 1843
DO U HAVE ANY QUALITY IN THAT TP'S
Post Number: 30
I TOLD YOU GO BLOW A CAMEL !!!!!!!
Username: Nydas
Post Number: 10508
Do unto others what you would have done to you.
Do to yourself what you want to to do to others.
