PVRSW-080504A-II.PGM No audio or video
Username: Chadap
Post Number: 24
Does anyone had any success in getting PPV and 118.7 International channels with new file in VS PVR7000. Since this afternoon I try to load this file and it still stuck on Auto roll processing. I did hard reboot, tried old file, but still no luck.
Username: Kirankumar
NO Bashing
Post Number: 2715
after you have loaded latest fix
do hard reboot
make sure auto roll is on
then leave it on any one of the 118 channels until picture comes up.this may take up to 10 minutes.
do not keep changing channels until picture comes up
Username: Chadap
Post Number: 25
African, After I loaded the channel, I unplugged from back and plugged in again. And stayed on 802 for 20mins and 799 for 30mins and 811 for 40mins, still no luck. Is there any specific channel you were stayed on. I will try the same thing.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2167
African i have delete all provider(nagravision) on Bev
maybe its why i dont have problem.
Username: Chadap
Post Number: 26
Yesterday's file had a new addition, which is updated sat file includes Anik F3. Since I had my own customized sat file for 118.7 earlier, the new fix overwritten my sat file and is the reason I was not able to get programs on 118.7. I fixed it ant it worked.
NO Bashing
Post Number: 2721
can you make sure your auto roll is on
Username: Chadap
Post Number: 28
yes auto roll was on.
Username: Chadap
Post Number: 29
Auto roll was on
NO Bashing
Post Number: 2723
can you make sure your antenna settings have not changed
post here please
