Just can't get 61.5 dish signal..
Username: Saqeeb9000
Post Number: 3257
tried every thing..
what is the freq should be..
lnb freq is set to 11250 but what about freq?
Username: Kirankumar
NO Bashing
Post Number: 2628
try 12362 tp freq
Post Number: 3258
vertica or hori
Elevation: 14.0°
Azimuth (true): 120.8°
Azimuth (magn.): 104.3°
LNB skew: -32.7°
lnb skew is -32.7 but mine goes from 0 - 90 .. no negatives?
Post Number: 3259
i am using one dish with 2 lnb's but still not able to pick 61.5
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2068
Where are you located Sada (city)
The good Tp is 12297
Post Number: 3260
calgary canada
Username: Plymouth
Post Number: 2069
Sada i think you are out of zone
You can try Tp 12414
This the Tp for installer
Username: Lklives
Post Number: 15482
LNBF Polarization Tilt (skew):
Your LNB is marked with a label indicating the polarization tilt. Your local LNB polarity offset information varies by location. If you are in Houston, TX your LNB polarization is to be set at 0 degrees. But if you are on the California coast your LNB polarization could be as much as minus 30 degrees (clockwise rotation). And if you are in Maine your LNB polarization could be as much as plus 30 degree (counter-clockwise rotation). Peaking the dish and adjusting the polarity of the LNB will greatly improve your Signal Quality reading.
www.dishpointer.com
Address: Calgary canada
Latitude: 51.054°
Longitude: -114.062°
Satellite: 61.5W Echostar 3, Rainbow 1
Elevation: 14.0°
Skew: -32.7°
Username: Plymouth
Post Number: 2070
You need dish 110 cm for your location
http://www.dishpointer.com/satellites/
NO Bashing
Post Number: 2632
Sada,
forget it you are not going to get it
if the elevation is showing as 14 you will not get 61.5
sorry
Username: Little_bear
Sudbury, Ontario Canada
Post Number: 69
sada
From your location @ 14 degree elevation
you will need a clear line of sight and
a 36" to 48" Dish.
Username: Plymouth
Post Number: 2074
You are right Desert Fox
Post Number: 3262
ok thanks a lot.. i have 18 inch dish.. so it won't work
thanks again all you guys for help
Username: Pulpfiktion
Post Number: 197
Mr. Sada -
PEST LK says
Elevation: 14.0°
PEST LK does NOT understand this. It means the elvation is NOT good for your location.
Try getting Echo 1,2 from Calgary.
There use to be The One posting here b4, and he is not here. He would tell U. Ask him.
NO Bashing
Post Number: 2636
Sada,
look for a cheap 30" or larger dish and get 118
that will be the best solution in the long run
Username: Lklives
Post Number: 15496
Cockroach...with the right size dish those co-ordinates work...
do what U do best here...NOTHING...and post lies and bogus info!
Username: Nydss
Post: 10389
Pest Control you are a troll. Leave my friends alone or you will be sorry.
