How to change the degree
Username: Anairis07
Post Number: 41
i jtag one of my box came to life. then when i programmed with the b-80 and last bin the 379 i scan and perfectly i got tv againg, but when i check the channel list there are some missing. compare with my other pansat i notice that the degree are not the same how i change that, and i only have three satellite on the antenna setup list can someone help me. why the tp san list not have all the list is because having wrong the degree everything change.
Username: Albino_midget
Post Number: 673
go into channel edit ,select delete , select the sat and press ok x 2.
do antenna settings for correct sat.
if thats what you are asking
