Username: Alexdell Post Number: 1 Registered: Apr-08
Thursday, April 24, 2008 - 17:13 GMT I just got this receiver and I loaded the 4/21 bin and the channels keep on freezing. Are others experiencing the same thing or perhaps my setup is incorrect. I'm using a DP44 switch with Dish 500+. Prior to the VS Pro, I had a c**lsat 6000 and it worked fine (except for the long wait for the bin fix). Please help. Alex
Username: Kirankumar NO Bashing
Post Number: 2565 Registered: Oct-07
Thursday, April 24, 2008 - 17:15 GMT is your dp44 powered up with external power source? if not then vs doesn't have enough juice to power the switch
Username: Alexdell Post Number: 2 Registered: Apr-08
Thursday, April 24, 2008 - 17:40 GMT Yes it's powered through the coax from my Dish DVR receiver downstairs since it's connected to the output 1 of the dp44 switch.
Post Number: 2566 Registered: Oct-07
Thursday, April 24, 2008 - 17:45 GMT ok i don't know where you got the latest fix but i want you to delete that file from computer and download fresh copy from the link i am giving you. do this write down antenna settings for all sats you have do factory default load factory bin then load new bin from link i have given do factory default adjust antenna settings and scan http://www.ftabins.net/showthread.php?t=36805
Username: Alexdell Post Number: 3 Registered: Apr-08
Thursday, April 24, 2008 - 17:52 GMT Thanks. I'll give it a try. Which file is recommended the old gui or the new gui (II)?
Post Number: 2569 Registered: Oct-07
Thursday, April 24, 2008 - 17:55 GMT follow the link i have given and download that
Username: Alexdell Post Number: 4 Registered: Apr-08
Thursday, April 24, 2008 - 18:01 GMT The link that you gave has two files: VSPRO-080421A (Old GUI) VSPRO-080421A-II (New GUI) Which one is preferred?
Post Number: 2571 Registered: Oct-07
Thursday, April 24, 2008 - 18:04 GMT new gui
Username: Plymouth Quebec city,
Quebec
Post Number: 2036 Registered: Jan-08
Thursday, April 24, 2008 - 18:24 GMT African i'm affraid by retouch bin If it is for correct bug thats OK Retouch can have bug insert Ftabin is good site DsstesterDOTcom test and work fine no need login
Post Number: 2573 Registered: Oct-07
Thursday, April 24, 2008 - 18:46 GMT it's fine by me where he downloads the file from,i was just trying to help when there was no one here to help, and the only site i use to download files is ftabins,had no problems so far good luck
