Problem with 2500/flu converted
Username: Bodie1
Can anyone help with 2500/flu converted--I had the puff/lzma files; well i jumped the gun and loaded a plain puff and the reciever just keeps puffing & powering off & puffing it keeps doing this. I have tried to reload the boot60 a dozen times & it won't take. Any suggestions?
Username: Desi_munda
Post Number: 163
just reload the latest Lzma BIN file, and in the loader select BIN FILE not boot file.
and it should work.
if not, let me know at gulzarh@msn.com
Username: Nydas
Post Number: 10266
There is no valid LZMA BIN.
You have to do a revert to
b60 boot
294T Bin and then reconvert to b75 boot/BIN or PUFF boot/bin
then latest BIN b75 or PUFF depending upon what you chose.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF
http://public.box.net/2500_full_kit
Username: Bodie1
Post Number: 7
Hey we are back in business. I should have thought to put an old puff/lmza bin back in; then retried the b60 and it took. That thing was in puffing limbo, but it is working fine!! Thanks, you folks are the best!!!
