USB to serial problem - pansat 3500 sd
Username: Pungi
Post Number: 37
I am trying to make USB to serial work for my pansat 3500. I have installed the drivers and changed the bit-rate using device manager in the control pannel. The problem is, it starts transfering the file but always it fails in between the transfer process. It gives the message "Flash update failed". did anyone have similar problem? any suggestions? Thanks in advance.
Username: Dimwitt
Post Number: 600
i would get- USB SD Card Reader- and SD card.
no more disconnecting 3500.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1877
If that start to download your port is OK.
Try to force loading with a old bin and reload this bin
Username: Cartier1
Post Number: 1812
you will never make it with pansat. some computer uses usb to serial they work good . some no way. dont waste your time you wont solve this problem. i flash any box but pansat using my comouter usb to serial. im not sure but have you ever formated and instaled windows in your computer ?
Username: Pungi
Post Number: 38
Thanks all for your reply. I have tried everything I could do and now i gave up as cartier1 suggested.
To Tooter: My pansat 3500 sd even gives me problem with sd card load. It stuck with b-80 all the time i tried bin loading using sd card. Thats the reason I tried usb to serial, but no luck even with that. seems like I have no other option but to use my old pc to do the bin loading using serial null modem cable.
Username: Lklives
Post Number: 15410
USB to Serial Cable Help
[link removed]
Username: The_coders
Post Number: 927
Username: Lklives
Post Number: 15413
coders aka pulp...U really lack any creativity..and are quite boring...your stuff is really lame!
Username: King_of_sats
Post Number: 36
your stuff is really lame!!
Has to be the second biggest oxymoron statement made to date by the OLD LADY.....OMFG LK is the flaming lady Macbeth of ecoustics herself..
whats the saying LK
"hell hath no fury like a woman scorned"?
copy&paste another 15413 message and give us all a update on true meaning of "your stuff is really lame!" OKAY!!!
