Cw800pvr
Username: Eh1012
Post Number: 33
i cant seem to load the file into my new cw800 im new with this receiver any help works thanks
Username: Kirankumar
NO Bashing
Post Number: 2482
you need to download latest file to computer and unzip it ( you will need winrar to unzip it) then send unzipped file to usb stick.then insert usb stick in receiver and download
NO Bashing
Post Number: 2483
you can also follow this link it is very useful.if it asks for registration,do so it is free
http://www.ftabins.net/showthread.php?t=9302
Username: Brucester
Post Number: 1432
C&P
How to load new CW800 wit usb or cable
Download/Unzip files.Transfer files onto USB stick then plug it into the box. You should see a message that says USB ready. Now press the USB button on remote and then scroll to the right to open Software tab.Look for file and press OK to load it. After it loads it will ask you if you want to reboot say YES. When it reboots then go in menu and do a Factory Default. Then reboot again . When it comes back up now you can setup sats and options and rescan all sats. After done with that exit out of all menus and with remote press F1 000 to enable the Patch. You should see a message on tv that say PATCH ENABLED. Now wait for keys to roll and watch tv
cable instructions
Prepare receiver:
Turn off and attach the null-modem cable between the receiver and the computer serial port.Then plug in the power plug.
With the CaptiveWorks 800 receiver off, press the front power button and hold it.
While holding it, turn the rear toggle switch on, while STILL holding front power button.
You will see "boot" on the front display.
1. Get the current loader - UpgradeCW800S (now 1.02)
2. Download the latest bin
3. Load the latest bin with the current loader as per these instructions:
Open the loader, select the latest bin in the "File" bar across the top.
For Options, select Download S/W.
For Select a port, choose your COM port (usually 1).Then hit the start/load &
wait for the receiver to display "-end".
At this point, turn reciever off at rear switch.
here you go no registration
Username: Eh1012
Post Number: 34
thanks for all the input.but the other problem im having is that when i hit start it doesnt do anything and ive tried all coms.i have windows vista and my friend has windows xp and his downloads it just fine any suggestion.
Username: Eh1012
Post Number: 35
ok i got it loaded but now my problem is that on my setting my 110 says 110 and 119 says 110 i cant get the settings right. i have a dp-plus lnb any suggestion
Username: Eh1012
Post Number: 36
i dont know if it matters but i got windows vista.i was also wondering how to put the channels in dish net order like on my c**lsat.
Username: Moly
Post Number: 14
do you have your receiver recognizing which lnb is connected to which diseq port, and do you have your receiver recognizing that it is getting channels from more than one lnb?
Username: Eh1012
Post Number: 37
i have a cw800s receiver and im not sure how the settings go and he to put the channels in dish order i live in central california.
