Username: Adave Post Number: 171 Registered: Jun-06
Wednesday, April 16, 2008 - 18:53 GMT pls let me know how come i get on both lnb but i am not getting strong signal for sv8000 but good for coolsa 5000.
Username: Kirankumar NO Bashing
Post Number: 2496 Registered: Oct-07
Wednesday, April 16, 2008 - 19:00 GMT signal is not important as long as you get good quality,and on sv receivers the quality may show low but you will get channels working good,as long as you are getting all available channels leave the set up alone and enjoy
Username: Doa Post Number: 56 Registered: Jul-06
Wednesday, April 16, 2008 - 20:35 GMT Make sure your switch settings are correct. You may have both set to the same switch.
Username: Adave Post Number: 172 Registered: Jun-06
Wednesday, April 16, 2008 - 21:25 GMT no i use the both diffrent reciver with diffrent switch thax for reply
