i am haveing a hard time figuring out my nfusion i downloaded a step by step tutorial but can not get things to work what is the latest file for this resiever and were can i find it thanks for any help
i have loaded all the proper bins in the proper sequance but still no tv am i missing a step and how do i get the guide do i need to loaad a channel list and if so witch one i do get the nasa channel and the info channels so every thing is good in that respect thanks for your help>
First set your dish settings/ Menu/ OK/0000/Installation and then set all your sat settings and save
Hit menu on remote control/Installation/ OK/ 0000/ Scroll down to Channel Scan/OK/Satellite/OK/scroll to Sats and press OK on each Sat you want to scan / OK to put a heart beside each sat that you have setup outside / once done press the Menu key again/Scroll down to Multiple Sat Search/press right arrow key to get the search feature/ OK and all your Sats will scan in one run
bob u said no tv, ? did scan all the dishes? if you did go to menu, internet , sw version check. make sure u have latest bin (1.452) ..\ as long as the red light is on in ur front of reciever, that means ur internet connections is good, and it should work, which sat is nasa channel on, u can do a advance scan on nfusion, by go to menu, installation ,channel scan, click on add tp, put down freq for specific channe, symbolrate, and click on search channel.
Visual, did your parents have any kids that lived? Better yet, do you know your parents. They can't be to proud of you. When you were born the doctor slapped your mother.
yes i am hooked to the internet my problem i believe is maybe the bin i can load the factory bin and the 130 boot and i get the good on the front of the stb but wheb i try to load the 145 bin i just get 9enu i have tried a few diffarant ones but its always the same and they come from the nfusion site is it something im doing wrong and it dosnt matter if i select boot or main on the loader?
thank you to all for your exallent help i have it up and all is well it turned out to be a bad file found one at dss central lots better than my old pansat 2500 although that one treated me without any problems for 5 years and i would still recomend pansat as a resiever would still have it if it were not for a power flash last time i tried to up date could still be jtaged i guess well happy tv watching and thanks again>
