New member Username: SpcmanBig D, Tx Usa Post Number: 1 Registered: Apr-08 | Previously, international chinese chn on Sat 121 moved to Sat 119, but now they are gone. Did the Sat move to a different angle again? Thank you in advance. |
Bronze Member Username: Buyer2007Post Number: 86 Registered: Mar-08 | Check sat 118 |
Gold Member Username: KirankumarNO Bashing Post Number: 2445 Registered: Oct-07 | go to www.lyngast.com for all listings |
New member Username: SpcmanTX Post Number: 2 Registered: Apr-08 | Yeah, I might have gotten sat 118 (instead of 119)because I was able to watch those chinese chn for a week or 2, and then they are gone. African, The link you provided contain only advertising links. No helpful info. Thanks in advance for the help. |
Silver Member Username: Madflea168Post Number: 409 Registered: Jan-08 | african had typo, it is lyngsatdotcom make sure you have the right lnb for the bird. they are all on 118 now. good luck. |
Bronze Member Username: FortecuserToronto, ON Canada Post Number: 27 Registered: May-06 | MF: how do I set my sat to 118. I have pansat 2700 clone and get everything except the international channels. Pls help me. thanks |
Gold Member Username: KirankumarNO Bashing Post Number: 2461 Registered: Oct-07 | RC, look at the other thread also to get 118.7 you need a 30" or larger dish and you will have to get a new lnb for 119/118.7 ( about $20} so with 2 lnb's you will be able to get 119,118.7 and 110 on one dish |
New member Username: SpcmanTX Post Number: 3 Registered: Apr-08 | MF, You're right about typo link. Got it. Thanks. African, Is the lnb for the 118.7 sat same type as 119 sat? Currently I use different lnb type for international chn 119 and PPV 119. Thanks again. |
Bronze Member Username: TstdrivrU.S.A. Post Number: 100 Registered: Dec-07 | if you want accurate and up to date channel lists go here |
Silver Member Username: TstdrivrU.S.A. Post Number: 101 Registered: Dec-07 | this is extremely accurate for echo anyway. |
Platinum Member Username: NydasPost Number: 10110 Registered: Jun-06 | CB2008A This is the LNB for the new 118W (Anik F3 / 118.7W / 118.8W) satellite. With this special LNB, you can get BOTH 118 and 119 at the same time! Works with both Free-to-Air and Original DN Receivers! Requires: 30-inch or larger dish. 20' oval may work but is unreliable and YOU WILL MISS some channels. Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and legacy switches (SW21, SW44, etc) Not compatible with DishPro switches and/or DishPro (stacked) LNB's SPECS Polarization: Circular Input Frequency: 11.70 - 12.75 GHz LO Frequency: 10.750 GHz Noise: 0.5 dB Dual-output (ready for 1 or 2 receivers). Each output will give you both 118.7W and 119W. SETUP INSTRUCTIONS Using a 30-inch or larger dish, aim with the following settings: Satellite Name: 118A°W (Anik F3) or 119A°W (Echo7) LNB Type: Standard (or Single) LO Frequency: 10750 or 10600 MHz Finally, do an AUTO SCAN or a BLIND SCAN For some the following settings may work better or give you more channels: LNB Type: Universal LO Frequency: 9750 MHz HI Frequency: 11750 MHz ALTERNATIVE SETUP The lnb is good for 118.7, but may not receive all channels/transponders for 119 as the highest frequency of the LNB is 12.2 GHz. The normal 119 LNB goes up to 12.70 GHz. According to lyngsat (http://www.lyngsat*com/packages/dish119.html) the highest transponder frequency in use now is 12.516GHz. You may get around this by doing two scans. One with LNB frequency set at 10750 or even lower and then another scan with LNB frequency set at 11250. alternatively scan each one of the missing transponders of Echo 9 separately using LNB frequency 11250. WHERE TO BUY: You can try ebay , search for Superdish type1 to 500+ repoint kit -part 148328. This contain the LNBs to retrofit the Superdish. If you have a 33" dish (other than Superdish) you can get the CB2008A lnb which will get 118.7 and 119. CB2008A is available at ebay and many other online stores. <b> this is one of the hottest items on the market, so please do not ask '" just Google for it and you will find it. MECHANICAL CONSIDERATIONS: CB2008A cannot directly replace the 119 LNB on the Superdish. Superdish lnb for 119 has a special bracket. If you are good mechanically ,you could probably figure a way to mount it on the Superdish; - it is not impossible. Iit requires a rectangular mount similar to those of DTV. The mount for Dish LNB have one side that is semicircular. If you have a Superdish the best bet it to get the Superdish type1 toDish 500+ repoint kit part#148328. Caution: There are many on this forum whose only purpose in life is to try and ruin my posts or discredit me. The write up above is modified (deliberately) from what is already available and posted in another very reputable forum over 6 months ago. I have checked each statement to make sure it conforms to my own knowledge about it. |
Platinum Member Username: LklivesPost Number: 15348 Registered: Jan-06 | Converting to PUFF_1.0.1 from any (B-75/Lzma/Old Puff) The most common factor lately, seems to be the loaders that work for some and not for others... thats a matter of trial and error on your part. The ones I have listed have been tested and work for me, so if it works for you...use it. Or READ around they're easy to find. If you keep a channel list...save it before proceeding as this following will WIPE CLEAN any and all settings you had. Open UkRoNiCs BOX Updater .420. select -Ukr_PUFF1.0.1_ConvertBOX.bin Using rear switch OFF/On....on first lights hit the write button...box will reboot into 'rolling PUFF'--this indicates 'waiting for PUFF bin'. Using same loader..no need to OFF/ON the box at this point (but it wont kill it if you do),select the Team-PUFF bin of choice up to the latest 262 hit the write button when ready, box will again reboot, will pause of last 'F', and turn ON. This brings up the language screen and the rest is up to you. BTW...no need to set default keys--but couldnt hurt* |
Platinum Member Username: NydasPost Number: 10118 Registered: Jun-06 | LK HAS BEEN PUFFING!! As I warned before She WILL show up to disrupt!! |
Silver Member Username: GregrafPost Number: 127 Registered: Dec-07 | Nalin your a b!tch it was nice and quiet here for the last day or so. No wonder no one likes you here with your sh1tty attitude, Beware Nalin Nydas |
Platinum Member Username: NydasPost Number: 10127 Registered: Jun-06 | LK aka greg raf: You idiot - you have been puffing and don't even remember what Nick you last used. |
Silver Member Username: GregrafPost Number: 129 Registered: Dec-07 | Your just here to ruin this forum. But being a Dish Mole youd like that EH |
Platinum Member Username: NydasPost Number: 10138 Registered: Jun-06 | LK aka greg raf. You are the only one ruining the forum. |
Silver Member Username: GregrafPost Number: 133 Registered: Dec-07 | Nalin nobody smart wants you here you B!TCH. |
Silver Member Username: The_codersPost Number: 905 Registered: Jan-08 | the "Rat" has 133 posts and all used to bash Nalin , if you took LK's ballsack outta yur mouth for a sec ya mite be able to actually help someone , but yur not here to help anyone are ya |
Silver Member Username: North_of_ontarioPost Number: 699 Registered: Sep-07 | |
Silver Member Username: The_codersPost Number: 907 Registered: Jan-08 | maple leaf (or is it make believe) and the GAYNATION rofl - good name for such a loser ! another LK baglicker |
Silver Member Username: GregrafPost Number: 134 Registered: Dec-07 | Coders, Nalin Nyda is a LOSER stop using my word. |
Silver Member Username: North_of_ontarioPost Number: 700 Registered: Sep-07 | better than being a Nalin's azz Iicker like yourself...... |
Silver Member Username: The_codersPost Number: 908 Registered: Jan-08 | the "Rat" has 134 posts and all used to bash Nalin , if you took LK's ballsack outta yur mouth for a sec ya mite be able to actually help someone , but yur not here to help anyone are ya |
Silver Member Username: GregrafPost Number: 136 Registered: Dec-07 | Nalin Nyda is a LOSER |
Silver Member Username: The_codersPost Number: 910 Registered: Jan-08 | |
Silver Member Username: North_of_ontarioPost Number: 703 Registered: Sep-07 | |
Gold Member Username: KirankumarNO Bashing Post Number: 2464 Registered: Oct-07 | perfect example of a help thread ruined there is no need for it there are so many bash threads here why not pick on them and bash the hell out of them |
Silver Member Username: Madflea168Post Number: 410 Registered: Jan-08 | I would assume the others may be similar to the vs. as for now, only vs ultra has updated sat info. with the other vs, the circulating thread about the 118 is either create a new sat/modify 119/modify 121. since I have dp lnb and only modify 121 tp list worked for me. delete all the tps in 121 list, and add 11715-20000-H-7/8, network is on. will able to find the rest of the tps from auto scan. lnb:ocs-dp freq:10750 good luck. |
Silver Member Username: GregrafPost Number: 137 Registered: Dec-07 | ya African look who started it in this thread the wicked witch Nalin Nyda |
Gold Member Username: KirankumarNO Bashing Post Number: 2465 Registered: Oct-07 | mad flea good post, Mad Flea Silver Member Username: Madflea168 Post Number: 410 Registered: Jan-08 Posted on Sunday, April 13, 2008 - 02:17 pm: Edit Post I would assume the others may be similar to the vs. as for now, only vs ultra has updated sat info. with the other vs, the circulating thread about the 118 is either create a new sat/modify 119/modify 121. since I have dp lnb and only modify 121 tp list worked for me. delete all the tps in 121 list, and add 11715-20000-H-7/8, network is on. will able to find the rest of the tps from auto scan. lnb:ocs-dp freq:10750 good luck. my understanding was if you load the factory file 132 it shows up 118.7 on receiver.worth checking out} |
Bronze Member Username: Little_bearSudbury, Ontario Canada Post Number: 42 Registered: Mar-08 | Sunday April 13,2008 The Rat 10:47 am: The Coders 12:58 am: now here comes you know who? The Queen Maple Leaf 1:04 pm: The Coders 1:14 pm: The Rat 1:17 pm: Maple Leaf 1:18: The Coders 1:19 pm: The Rat 1:25 pm: The Coders 1:30 pm: Maple Leaf 1;37 pm: Hay, Coder it looks like the Rat and the Queen were trying to box you in. Too close to call ,it could be one pperson???? BTW Maple Leaf, why do you always post your boy friends pictures, do that turns you on honey? what about you and I getting together and play little bit of touch football? I promise not to hurt you. |
Silver Member Username: North_of_ontarioPost Number: 706 Registered: Sep-07 | "....do that turns you on honey?...." lol......talkin' like the faggoty pussyboy you are......... . |
Silver Member Username: The_codersPost Number: 912 Registered: Jan-08 | |
Silver Member Username: North_of_ontarioPost Number: 707 Registered: Sep-07 | |
Silver Member Username: GregrafPost Number: 138 Registered: Dec-07 | This is a picture of Coders after sex with Nalin. |
Silver Member Username: PulpfiktionPost Number: 122 Registered: Mar-08 | This is a picture of LK after sexx with greg raf . |
Silver Member Username: GregrafPost Number: 150 Registered: Dec-07 | Nalin Nyda is a LOSER |
New member Username: SpcmanTX Post Number: 4 Registered: Apr-08 | Please DON'T Ruin this thread with trash talks. THANK YOU. African, Nalin, tstdrivr: Thank you for the feedback! |
