Silver Member Username: Desi_mundaPost Number: 155 Registered: Nov-07 | hi! i have convert my box to PUFF, so since yesterday the dish is gone, can anyone tell me if there is a new bin for that receiver or i should convert it to another system. (please dont say read other post, because i already read and no understand) i will apreciate ur answer. |
Platinum Member Username: LklivesPost Number: 15372 Registered: Jan-06 | PUFF bins are up fine now on both DN and Bev...either U probably have wrong keys, wrong antenna settings, or some operator error mistake.. |
Silver Member Username: Desi_mundaPost Number: 156 Registered: Nov-07 | what is the new bin? |
Silver Member Username: Desi_mundaPost Number: 157 Registered: Nov-07 | yes u r right its working, the problem is signal. i have scan on Echo3 and i have some channel working and some r not working. the signal is 71 percent. when i tune to Super Geo then the signal go to 0 percent and same thing with SONY Entertainment channel. i will apreciate it if anybody tell me about this. let me know if u nee more information, |
Bronze Member Username: AbeyambuPost Number: 12 Registered: May-06 | dear friends : what is a PUFF bin? where can i find to learn about it? |
Silver Member Username: Desi_mundaPost Number: 158 Registered: Nov-07 | any clue? |
Platinum Member Username: NydasPost Number: 10152 Registered: Jun-06 | abe rais: Everything for 2500/Flu to 2700 conversion in one package. Instructions included. http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or PUFF files If you have b75 boot, you must use b75 section for b75 BINs or you must convert to PUFF boot to use PUFF BINs If you have PUFF boot, you must use PUFF BINs. If you do not have PUFF BOOT, you MUST first convert to PUFF BOOT using the 640 K 253 version file before installing the latest. Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Platinum Member Username: NydasPost Number: 10153 Registered: Jun-06 | Hussain: Note down the antenna settings of all antennas. Do a reset - factory reset. do user setup Switch off at back and on. Do antenna setup of one sat. Do a Blind scan- power scan. Do other sats antena set up and Blind scan |
Silver Member Username: Desi_mundaPost Number: 159 Registered: Nov-07 | ok |
