Help with Nwe NFusion
Username: Mshah2006
Ontario Canada
Post Number: 130
Hello Sada.. I have purchased new NFusion Receiver. I need to know which bin files should I load onto my receiver. I did program it for Echo 3 and Echo 7 but there is none of the channels turn come on. I am asked by Nalin to ask you for help. I thank you for your help and cooperation.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1592
Mr Shah
Read this on stanby Sada
http://www.kashbrand.com/Nfusion.html
Username: Saqeeb9000
Post Number: 3088
MR shah u need bin 1.452..this will give u step by step instructions with lots
of pictures..
[link removed]
download the loader,bin 1.452, then u willl see internet option on ur rec menu option, plug in ur network cable, set it and forget it...
make sure when u are loading a bin only one time via ur serial cable, let it completly download , first time u need to do with old fashioned way using cables.
let me know if u need any extra help...
official/good sites for nfusion
[link removed]
[link removed]
Username: Metallica
Post Number: 583
BUMP...
Shah go here for your Nfusion and try to remember the topic of the thread you created so next time you know where to look for.
Post Number: 3100
yeh good idea. mr shah..
