Neosat
Username: Kille
Post Number: 60
I have 2 cs5k's..lucky me! But I have a chance to get a used neosat ipro 1000 for around 40 bucks. I know nothing of these receivers and wondered if they were even still supported? Do you think this is worthwhile? thx in advance
Diamond Member
Username: Lklives
Post Number: 15153
support is very limited for the 1000...I wouldn't..
Username: Kille
Post Number: 61
thanks LK
Username: Saqeeb9000
Post Number: 3061
don't buy the rec..........
the new models are 2000 and + and they also don't have great support.........
i think for 1000 they took out the support.....
Username: Chow
Post Number: 25
dont buy the neosat 1000 your gonna be so mad if you do i have one im gonna take it apart and recycle the chip board for 50 cents.if your looking for a cheap but ok receiver get a fortec ultra or a pansat 2500 on ebay
