Vs ultra stuck at "Boot"
Username: Budgie123
Post Number: 32
after loaded the 080403 release. Hard reboot stop at the same place ( "-----" then "Boot", then stuck there, that's it)
have to revive it use old bin.
anyone know what to do?
Username: Kirankumar
NO Bashing
Post Number: 2306
power off unhook co ax cable and power back on
Username: Madflea168
Post Number: 401
always unplug the coax before loading the bin to be safe.
if afican's method not working, try to reload the bin again, may have to use the cable if needed.
good luck.
Username: Nydas
Post Number: 9794
PFTAUSW-080404U DN & BEV Fixed
fixes issues with both providers plus includes additional features and changes to Menu system.
Please see Release note for more info.
- Boot Changed
- Support USB Boot Download(Filename Must be "PFTAUSWR.PGM")
- Satellite File Changed
- AV Settings and Option2 menus are Added.
- Factory Default menu moved to System Information.
- USB File Upload Method Changed
- You Can set Standby EPG Time.
- The Channel You Saw in EPG doesn't Save.
- Progress Bar Display When USB Download
- Bug fixed - Rebooting after Channel Scan
Username: Budgie123
Post Number: 33
unplug the feed and load does not help, same result. thanks for the suggestion.
like I said I used serial to do the load same result too.
i guess this is somehow related to vs anti clone practice but not sure.
Username: Budgie123
Post Number: 34
I am surprised no one else is having the same issue... I guess all clones are killed long time ago.
NO Bashing
Post Number: 2323
load 1.58 that will solve your problem
enjoy
http://www.ftabins.net/showthread.php?t=34322
Username: Scott21
Post Number: 27
I just did one the same, just load fractory 131 or 132 and do it 3 times and then new bin and you should be good to go . good luck
Username: Budgie123
Post Number: 35
African, that is for CaptiveWorks, are you sure it also works on viewsat ultra?
Username: Budgie123
Post Number: 36
scott21, that's interesting to know... Exactly what was your problem and what you did ?
I tried load 131 then 080404 still stuck at "Boot".
