Convertion 2500
Username: Freedom_rites
Montreal, Qc Canada
Post Number: 26
i tried to convert my (converted reciver 2700 b-75) to puff with Ukr_PUFF1.0.1_ConvertBOX.zip . but it goes to 68% and it gives an error " write failed er1" im using the same cable i use for updating new bins. any help....?
Username: Luser
Post Number: 193
Convert back then forward.
Username: Felt
Post Number: 29
looks as if you are using the wrong file i think that one is for the background image only
Username: Nydas
Post Number: 9862
You must read instructions properly.
go to
http://public.box.net/2500_full_kit
and download from puff section - either the quick method or the full_kit method and then follow the instructions properly and fully. If in doubt, just go back to b60 Boot and start all over again.
There are no short cuts.
Username: Bill038
Post Number: 652
If you listen to nalin, the wicked witch of the north, she will kill your box, send you to hacked sites and turn you in to DN.
Check her post counts, that is really the number of boxes she has killed. Do you know when she is going to kill a box.......................The next time she posts and someone takes her advice.
Stay away from her advice, she is here to send you to hacked sites and kill your fta box.
