Satellite TV
Username: Polyak
Hello guys. I am new in here, please help me to set up satellite TV.I have reeiver Vortex-Pro 7700.Have no idea what to do. Thank you.
Username: Saqeeb9000
Post Number: 3047
ok polstar here are couple of items you need to get started....
u need a fta reciever...
right now nfusion, viewsat ulta , sonicview... all good to buy ...
i will recommend nfusion, b.c it takes less maintenance but this rec also need a wireless router/inter connection..
if your tv is close to ur comp... it will work fine, if your tv is far away / then u also need to buy netgear...
ok now which dish u need...
depends on what kind of channel do u watch
normal tv station, ppv movies ,sports , foreign , ppvs, por*n etc........
any normal dish will work fine..
then u need to install dish , there are differenet directions depending on what kind of channels do u like...
110........ is good for ppv's (lots of ppvs)
119 ........lots of us network channels..
148 .... mostly foreign channels (indo/pak)
91............canadian channels+ppvs
u can add/install more than one dish..
here is the link for what kind of channels are offer in what direction
www.l*yngsat.com (remove *)
Username: Nydas
Post Number: 9774
Pol Star: The receiver you have is a Pansat 2500 clone. There is a conversion available for it and you should get 100 results with it. However, currently there is a total black out because of ECM by the providers. Wait a day.
