Coolsa*t 8000HD
Username: Pu_da_munda
Post Number: 81
I have CS Upgrade V3.01 loader for loading BIN File CS8000-11428F.sgn. Is this is the latest file and how to upload the bin in Receiver?
Post Number: 82
can anyone help me
Diamond Member
Username: Lklives
Post Number: 15101
Yes that is the correct loader and latest file...BUT the file is NO GOOD NOW...we have an ECM in progress and U need to wait for Coo*lsat to release a newer file..
Username: Saqeeb9000
Post Number: 3049
yes this is the latest file...... does this rec come with a usb slot or not?
if yes just download the file , extract it save it on usb// and then upgrade it to ur rec..
here are some sites where u can download/ help for this rec..
[link removed]
[link removed]
Username: Extremex
Post Number: 195
You have the latest bin, but the bad news is that it is not working. You will have to wait for a new bin.
Post Number: 3050
PROGRAMMING THE C*oolSAT 8000HD
A. Installing the Firmware
Step 1
o Ensure the CSReceiver is off, rear switch is in OFF position
o Run the CSUpgrade_v3.01
o Select the following settings and :
�� MODE -- Download
�� TYPE - Firmware, channels
�� SERIAL PORT -- match the number assigned by your USB/Serial
�� Click BROWSE and find CS8000HD_11169A.sgn
�� Click OPEN PORT and go to the next Step
Step 2
o Turn CSReceiver on from the rear switch
o When 'ld" starts flashing on the screen the receiver enters the Loading mode and can accept
programming. Click START in the CSUpgrade_v3.01 loader. If you missed it try again.
o DO NOT INTERRERUPT THE DOWNLOADING PROCCESS, or turn OFF the receiver during transfer,
the receiver's EEPROM could sustain MAJOR DAMAGE. Wait for the downloading process to
complete and the CSReceiver to boot by itself.
o DO not use the PC or Laptop while transferring data. Close all other applications. The transfer will
take a lot of physical resources, it could stall or dump physical memory (blue screen) which will
stop the transfer and hard boot the receiver in the downloading mode.
B. Installing the BIN files
Step 3
�� MODE -- Download
�� Click BROWSE and find CS8000HD_11163F.sgn
Step 4
o When 'ld" start flashing on the screen the receiver enters the Loading mode and can accept
Page 2
C. Installing Key Extractor and load the keys.
Step 5
o Install KeyUpdate v8.2.8 on your PC and run it. This will pull or update the running keys into a file
Keys.key. You can check it by opening it with WorldPad or NotePAd
o If you receive error messages of missing files when attempting to run KeyUpdate v8.2.8 install
KeyUpdate Support Files v6.8.5+
o Open CS8000 Key Loader V1.0. and
�� Select your COM Port
�� Click CONNECT
�� Click DOWNLOAD
�� Search for the Key.key file in KeyUpdate V.8.2.8 folder
o Turn CSReceiver on from the rear switch. It will take only one second to transfer keys. When
message DOWNLOAD COMPLETE comes on reboot CSReceiver
here is the link for setup by step direction......
[link removed]
III.
Post Number: 83
Thanks everyone, till when we can expect new bin file
Post Number: 85
Thanks friends, till when we can expect new bin file
