Freezing on VS Extreme
Username: 360guy
Ottawa, Ont Canada
Post Number: 61
Am I the only one experiencing freezing as well as the odd slow auto-roll? I'm using the 080328X file.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1478
dave
Do a factory default and leload last bin (dsstesterDOTcom)
Rescan your sat, just to set port for switch, if you have
All info on sat supposed to be OK
Good luck
Username: Kirankumar
NO Bashing
Post Number: 2299
dave
there is problem with auto roll it is slow,but you should not get any freezing
Username: Plymouth
Post Number: 1481
African freeze is possible, some VS box have this problem.
It is a last bad bin who do this problem, with delay.
Username: 360guy
Ottawa, Ont Canada
Post Number: 62
Thanks to both Ply,Afr. I got a file from another site, same title, and then reloaded it.Everything seems OK for now. Your help was greatly appreciated.
NO Bashing
Post Number: 2303
dave,
in future download files from ftabins.net
Username: 360guy
Ottawa, Ont Canada
Post Number: 63
I've used them before but can't remember which site I got that first file from. I think it was ftatalk. Thanks again.
Username: Plymouth
Post Number: 1483
dave
Where you take the new bin?
Thanks for the info
