Lost Channels - Please help
Username: Palmettolola
Post Number: 15
For the past couple of months, I have experienced lost channels. I have VS Plat Lite and use Echo 7 & 8. Just out of the blue one time when loading a new bin, I lost half of my channels and can't get them back. I can't get ESPNs, Speed, HGTV, MTV, and many, many more! I have tried loading the factory bin, new bin, and the lastest SAT file, but still unable to get all the channels back. When I do an Auto Scan for ES 7 & 8, I ususally end up with duplicates of the same channels.
Is there anyone else that has experienced this and especially is there anyone out there that can tell me what I should try to do to fix it.
I know I can't do this until we get a new bin, but at least I can be prepared.
Thanks!
Username: Abj
Post Number: 547
make sure you have auto transponder setting to on..
Please post your antenna setting for further assitant
Username: Abj
Post Number: 548
hope you do have signal for both satellite... if you are pointing 119 , you should have 119 locked on your uppper right hand corner of the screen.
Same goes for 110.
Make sure you have assigned both satelite right port...
Username: Madflea168
Post Number: 390
people reported the bins erase the data sometimes, before you re scan, always make sure your antenna setting are correct.
Username: Luser
Post Number: 178
One way to get a good scan is go to channel scan delete all but one tp with good Q prob 12224. Make sure network search is on and hit scan. Return to channel scan and any tp's without channels change polarity and if Q signal appears rescan with network search off. It worked well with extreme.
Username: Tgyoung1
Illinois U.s.a.
Post Number: 31
on pansat 2700 how do you turn off network scan. have couple freq that not scanning in? 12457 for speed channel 12443? thanks
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1454
PalmettoLola
This is a virus from bad bin who attack on delay.
try it:
All viewsat box
"Write your sat info before"
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
switch off 10 secs on back panel
"New" do a factory default
and load last bin for your box (from dsstesterDOTcom)
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
Do setup on each sat and auto scan on each sat after for recover all channel
"Dont do a blind no need"
"Dont load factory bin"
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
Issue for problem on Viewsat
Thanks
Username: Netodss
Sky
did you see that ftamafia is getting bigger and better they have a new bin for cnx for b3v open up the 401 channel i think its sunday ticket or is it a apirl fools gag.... let me know thanks
