SV 4000 . What does factory reset do to this receiver??
Username: Book77
Post Number: 145
When you use factory reset do this receiver.
Username: Lklives
Post Number: 15031
There are a lot of misconceptions as to what a factory reset or factory default does. The simple answer is that it restores the receiver settings to their factory default state (the way they were when they left the factory.) This only changes user settings, not any loaded factory bins or fixes. This removes the satellite selection, antenna settings, channel lists, time settings, all the user settings. Their may be times that you will find it necessary to do a factory reset if you need to remove duplicate channels, unwanted satellites, or are having a receiver issue of some sort. After a factory reset you will have to restore all of your previous receiver settings and rescan the satellites for your channels. It is a good idea to always have a copy of your receiver settings to make sure that they are right after bin changes and in case you have to do a factory reset.
Username: Pulpfiktion
Post Number: 92
LK says he is loving it here.
Username: Postergirl1
Post Number: 178
Pulp Gets Pulp-erized
Username: Ftajack
Post Number: 60
Nasty Nalin aka postergirtl1
You have been warned and advised not to make personal attacks against members
Username: Lklives
Post Number: 15056
Go away kid ftajackshit...useless
Username: Ftajack
Post Number: 63
LK: You have started your spam of dsscommunity.
It has not gone unnoticed by the administrators.
