I have no Idea.....please help!!
Username: Smurf316
North Carolina
Hello all.
I am new to all of this and i'm going crazy trying to get started with FTA and how it works on DN encrypted channels.
whats a really good receiver to start off with the least hassle ?
I have a SUPER DISH (oval) do i need to change my dish ?
when the receiver gets zapped how easy is it to get it on again ?
do receivers come right out of the box ready to use or do i have to download something to it?
Any help will be wonderful. i am brand new to all this and have no idea where to start.
Username: Lklives
Post Number: 14994
heres where U start...ago to another site...u pick one of these..
www.southcoastfta.com is a good start and easy good receiver..
Your dish is fine
U will have to upload a new file and make some receiver settings adjustments with your remote, after you get it out of the box...should take u about 30 minutes.....BUT U should read for about 8 hours at least before U start..
Username: Lklives
Post Number: 14995
Your dish is fine
U will have to upload a new file and make some receiver settings adjustments and scan some satellites with your remote, after you get it out of the box...should take u about 30 minutes.....BUT U should read for about 8 hours at least before U start..
U will need to go up on the roof and look at your dish , and switches and write all the info down and save it..
Username: Nydas
Post Number: 9682
All FTA receiver come ready to reun Free to Air Channels. Many people want to run additional channels and downloads extra files call BINs and get extra channels.
When you have bought a receiver, you should join a forum which has files on the site.
I suggest that a Sonicview 4000 is a good buy.
A pic is worth 1000 posts!!
Post Number: 15551
WTF is going on......
Username: Cartier1
Post Number: 1785
NALIN YOU ARE NOT MAKING ANY POINT. THE GUY IS NOT ASKING YOU FOR FREE TO AIR. HE IS ASKING TO OPEN DN . SO NO NEED TO FALLOW LK IN EVERY FU8CKING SINGLE POST HE MAKES. HIS ANSWER WAS TOO CLEAR THAN YOURS. NALIN YOU WILL GET THE GUY CONFUSED.
Username: Nydas
Post Number: 9684
cartier1: I have answered within the legal framework. If you do not like my answer, you can give your answer. Nobody stopped you from answering.
Username: Mucho
Post Number: 158
Cartier, check this out.
BTW why are you hollering at Nalin?
He didn't holler at you. Very RudeUpload
Username: Smurf316
North Carolina
Thanks allot guys! a friend of mine has a VIEWSAT platnum. is this one good or could i do better?
Username: Nydas
Post Number: 9691
I think you will find either Viewsat ultra and Sonicview 4000 better and equal to each other in many ways.
The USB drive input in these receivers (for upgrades), is the big plus in these receivers.
Username: Weedees
Post Number: 7
this post is for nalin nyda i think have a problem with puff conversion with the flu I was talking to the $mart 1 and he said to talk to u
Username: Lklives
Post Number: 15020
Then the Smart1 aint too smart, if he said that!...why not call dishnetwork and ask them...same...same..
Username: Kirankumar
NO Bashing
Post Number: 2266
LK and Nalin,
very good advice
mike,
viewsat platinum is a thing of the past ,these two guys made great suggestions.
Username: Nydas
Post Number: 9698
gary janke: Go to
http://public.box.net/2500_full_kit
download what you need to. Read the instructions and se where you want to go from there.
Start a new thread if you want to.
Username: Smurf316
North Carolina
I keep seeing the USB FLASH DRIVE is not included.
what is this and do i need it?
NO Bashing
Post Number: 2267
yes you do,just pick one up locally with a small memory
NO Bashing
Post Number: 2268
also please type normally,you don't need to change the fonts.or make them bold
Username: Lklives
Post Number: 15023
Its a small portable "drive" that holds files and allows U to download or upload to and from it..its the size of a cigarette lighter, and plugs into your USB port in your computer and IF ya buy a USB ready receiver , it has a USB port in that too....so no need to have receiver next to computer, or connect/disconnect cables and carry receiver into another room where computer may be, every time U need to upload new files to the receiver.....it cost about $15 at any store, including Walmart!
Its (USB capable) a "MUST HAVE" nowadays when buying a FTA receiver..
Username: Lklives
Post Number: 15024
BTW...the Captiveworks (CW) 700 receiver is USB ready, for $109...thats a homerun!
Username: Smurf316
North Carolina
will i need to do any thing to my Super Dish?
NO Bashing
Post Number: 2278
does it have any lnb's?
if not then you need to get lnb's for it
Username: Lamborghini
I have been using CW600s P with good results 4 > than 1 yr. Recently I added one more of the same. I think the price differential is like 65+ 4 cw600p and 125 for cw800. Don't think usb is a big deal. Functionalities are same as LK said.
Username: Smurf316
North Carolina
yes my Super Dish has 3 LNBs i think. do i have to move or switch them or can i just leave them alone? I currently use it for Dish Network.)
Username: Nydas
Post Number: 9725
mike g harris: You will not need to change anything except:
Use the DN receiver (as long as it turns on) to power the LNBs and the switch(es) if any and use another port output for connecting to your FTA receiver.
Username: Rags
Message for Nalin Nyda.... Which is your fav board... SOS on FLU - its been sitting like a paperweight for 6 months. Am not sure what I need to do. Where can i connect with you?
Username: Nydas
Post Number: 9728
Yadav: I have answered you elsewhere.
