2700a Clone pansat....
Username: Jalaj69
Post Number: 155
Some one please tell me if their is a new bin for clone safe 2700a Pansat..
I just cant find TIVO bin...
Also where can i find LOTHARIO loader.....
Username: Nydas
Post Number: 9621
jay: Are you looking for a file for a clone Pansat 2700 or for a converted receiver? Clonesafe BIn for 2700 is different from BINs made by Lothario for converted 2500/Flu receivers.
Username: Jalaj69
Post Number: 156
i am looking for CLONE 2700a (pansat)
I need the file...i havent seen the TIVO bin n e where.......
is it out yet...
Username: Nydas
Post Number: 9627
The Vortex equivalent (clone safe) is there. I think you have to use a Vortex loader - 27.02 won't work.
[link removed]
VorteX 2700 #2060 (3-28-08)
VorteX2700_87VX_TiVo_080328_B75_2060
File Type: zip VorteX2700_87VX_TiVo_080328_B75_2060.zip (434.7 KB, 205 views)
Username: Jalaj69
Post Number: 157
please give me a link for the VORTEX loader...i cant find it...i have the file but i need the loader...!!!
thanks for the help
Username: Nydas
Post Number: 9629
[link removed]
At the top part you will see
Factory Bins
Loaders, Utilites, and Manuals
go into the desired section and get your loader, instructions etc.
Username: Jalaj69
Post Number: 158
thanks dog..ur always a good source for good info....keep up the good work man!
Username: Jalaj69
Post Number: 159
hey...NALIN..
I cant seem to attach the file to the loader...
it is keep on saying File Unknown TYPE...
u know what could be the problem.?
Username: 6709394
I load the VorteX2700_87VX_TiVo_080328_B75_2060 file for my c-2700.Bell is GOOD,but Dishnet121 cant"find the chinese channel,why? Before i use TIVO bin is no this problem.
Username: Nydas
Post Number: 9634
A lot of Dish 121W channels have moved to 118.7 Anik 3. Your problem is most likely due to the fact that "it ain't there" any more.
If you want you can get the 260 Clone-safe Tivo version and try with that, but I doubt if it will improve matters.
[link removed]
Pansat-C 2700 260v1 TiVo
Check in the www.lyngsat*com list under 121W. You may want to convert the existing setup to the 118.7 using a special $100 kit that DN has put out. Or you may want to consider using a special Universal LNB ($25) to catch 118.7/119. There are several threads on this subject at Ecoustics in the last 2 months.
Username: Mcrabbycabby
Wpg, Man Canada
Post Number: 49
nalin how come the bins went from 258 to 260 no 259 ? i was just wondering trying to learn something or did i just miss 259 thank you.
Username: Metallica
Post Number: 487
Terry..the 259 bin did come out but it a bad bin than hour later they changed it to the 260 bin a much better bin...that what happen.
Username: Mkvl1490
Post Number: 138
Do anybody have the 2700 back to 2500
i converted 2500 to 2700, and now i need the instructions in order to do this puff conversion
Username: Metallica
Post Number: 488
2700 to 2500.zip
http://www.ftabins.net/showthread.php?t=7477
Username: Mkvl1490
Post Number: 139
good looking
Wpg, Man Canada
Post Number: 50
ty metallica for answering.
