Jvvh_260.bin ?
Username: Espn3
Post Number: 257
Is there going to be a jvvh_260.bin for the FLUs converted to Pansat 2700 ?
Can I use the jvvh_Fortec_Pansat_260(PUFF). bin on my FTA ?
thanks.
Username: Freedom_rites
Montreal, Qc Canada
Post Number: 23
no john johnson no jvvh bin out yet. but there is one "260_p122654_AIO.bin - b-75 only!" works fine. just turn off the autoroll. it's only for b-75 . you cant use it on puff or you cant use puff files on b-75 so be carefull. you can get those bins from http://www.ftatalk*com
Username: Nydas
Post Number: 9537
260 Bins are out for
Pansat 2700 original - BIN 260
Conversion BIN B75_260
Conversion BIN PUFF_260
Conversion BIN PUFF_LZMA_260
Everything for 2500/Flu to 2700 conversion in one package.
Instructions included.
Either b75 or PUFF or PUFF_ LMZA
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or PUFF files or PUFF_LMZA FILES.
If you have b75 boot, you must convert to PUFF boot to use PUFF BINs or PUFF_LMZA BOOT to use LMZA BINs.
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Espn3
Post Number: 260
Thanks Jami, Nalin.
I loaded 260_p122654.bin and works very good.
Why they don't label this bin jvvh_260 ?
Username: Nydas
Post Number: 9558
Because it was a special effort by a guy who calls himself p122654, to solve the different keyboard conflicts.
Username: Bill038
Post Number: 607
If you listen to nalin, the wicked witch of the north, she will kill your box, send you
to hacked sites and turn you in to DN.
Check her post counts, that is really the number of boxes she has killed. Do you know
when she is going to kill a box.......................The next time she posts and
someone takes her advice.
Stay afrom her advice, she is here to send you to hacked sites and kill your fta box.
Username: Juanitobananas
Hi NAlin could u send me the files to my email?
Username: India101
Post Number: 37
so does this file(260_p122654.bin) work on PUFF Converted Receiver ?
Username: Nydas
Post Number: 9574
krish: Just download the conversion main file from the full_kits downloads and read it.
Then download the instructions from the appropriate subdirectory and read those.
Username: Bill038
Post Number: 620
Username: Nydas
Post Number: 9582
Bill Vickers:
You are becoming a big pest.
Get OFF this thread.
Username: Nydas
Post Number: 9583
