R 232 cable pansat
Username: Adrenalyzer
Post Number: 22
Hey wat do you do when your compu doesn't have an hook up for an r 232 cable???
Post Number: 23
hello
Username: Snuffles07
Post Number: 49
You need to buy a USB to Serial adapter. They sell them in most radioshacks and bestbuys but if your computer is running windows vista I suggest that you buy the Keyspan brand, it's the only one that works with vista.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1355
RS-232 is standard go to Radio Shack and buy one with 2 femals end wait minute i give info on wiring number.
Username: Plymouth
Post Number: 1356
OK connect only 3 wires and a ground
2 on 3
3 on 2
5 on 5
Ground on ground
Post Number: 50
What the hell are you talking about man? this guy already has an RS-232 cable, he just doesn't have the serial port on his computer. Stop confusing people.
Post Number: 24
thanks
Post Number: 51
No prob. Like I said, if you have vista on your comp DON'T BUY THE CABLE AT RADIOSHACK OR BESTBUY, buy it on ebay, amazon, or keyspan. com. Keyspan provides the vista drivers for the adapter.
Post Number: 25
wat i got was a new cable, 9 pin at one end(rs232) and usb at the other, it came with software, now, the compu came with vista, but i don't use, its not installed, don't like it.
when i select bin, and click write, it say it can't locate the bin file
Post Number: 26
actually, it says it can't open serial port, i dn loaded the software, hmm?????????????
Post Number: 27
when i select bin, and click write, it say it can't locate the bin fileactually, it says it can't open serial port, i dn loaded the software, hmm?????????????
Post Number: 52
First things first. Are you sure you're not running vista? If you are not running vista, download the drivers pertaining to whatever you're running on your computer and install the software and follow the instructions.
Post Number: 28
absolutly sure, i'm not running vista
Post Number: 29
absolutle sure, i'm not running vista
Post Number: 30
help
Username: Nydas
Post Number: 9586
Pansat 2500/FLU take a straight through RS232 signal (Pin 2 & 3 to Pin 2 & 3 unaltered)
Pansat 2700 and Viewsat Ultra take Null Modem RS232 cable (Pin 2 to 3 and pin 3 to 2)
USB to serial convertors are notorious for problems and for slowness.
Buy only the type with its own installation CD.
Do not allow windows XP to install it.
Manually install using CD
Select COM1, or COM2, or COM3 or COM 4 port.
Use device manager in your computer to check and select the right port.
Username: Nydas
Post Number: 9587
If you are not sure what DB9 F/F cable you have, it is a good idea to buy a DB9 M/F null adaptor or short cable.
With the null adaptor in you get one type and with it not in, you get the other type of signaling.
