BEV DOWN
Username: Carcpl58
Post Number: 80
Is BEV down? Been hearing that autoroll processing since last night. If it is any way to fix at the present time?
Username: Nakedgirl
FULLY CLOTHED, RECENTL..., Park Avenue
Post Number: 86
You might try telling us what fta you have??
Viewsats are all up I know that. Try turning on and off at back
Username: Kirankumar
NO Bashing
Post Number: 2232
last night the b@v ecm hit a few receivers,not all,
so like Naked Girl says,if you don't post your receiver type,we don't know the satus of your receiver
Username: Carcpl58
Post Number: 82
Viewsat Platinum
Username: Metallica
Post Number: 361
Jim try the older bin from Jan 26/27 for Bev but no DN..
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1074
Jim
try it:
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
no need to delete keys
switch off 10 secs on back panel
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll and search signal
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Do a blind scan on your sat after for recover all channel
Because some new freq are provide
Dont do a factory reset and factory bin
No need it
Reply if it work
Please
Username: Plymouth
Post Number: 1075
Metallica all VS work fine with it and last bin
Username: Metallica
Post Number: 364
OK..i don't watch Bev so i don't know what up..
i just saw Nalin post about some old bin can get your Bev back up..
OK cool Bubby.
Username: Carcpl58
Post Number: 83
Anyone know if BEV changed keys recently? If so what are the new keys? Sometimes they don't roll and have to be entered manually.
Thanks
Username: Metallica
Post Number: 365
Jim go head and try the keys you may get lucky.
[link removed]
Username: Plymouth
Post Number: 1076
Autoroll work very fine with it. No need to enter keys. The Box response is faster too. Many try it and reply it work.
Username: Nydas
Post Number: 9385
For genuine Pansat 2700 there is 258 BIN out at:
[link removed]
http://public.box.net/2500_full_kit
Username: Frankorock
do anyone have any advice for the Ariza 700? this is the first time in a long time since I got back into this type of thing and already its not working. I got the Mar.14th keys. Any help or guidance will be awesome.
Username: Nydas
Post Number: 9386
Look at these two areas in ftatalk.com. Arizas are working.
Ariza Discussins
[link removed]
Ariza Files:
[link removed]
