My PanSat 2700A Screwd up - Help Please
Username: Saika20005
Afterr loading and update boot file i lost all signals and even some menu settings e.g -Parental control. Please assist - saika
Username: Dimwitt
Post Number: 499
you need to do your antenna settings --select lnb type and dieqc port , for each sat you are aimed at.
parental control will return after successful satellite scan.
2nd receiver work in the same spot so nothing wrong in the dish settings. please assist for setup cofiguration.
Username: Nydas
Post Number: 9320
Look at the setup configuration of the receiver that is working and copy it.
Post Number: 7
Done, no luck
Post Number: 8
Hello All,
Here is my receiver infor deails as many of you requested for infor.
Receiver name and model: Pansat2700A
Boot file - 2700 A(B-75)
Bin file : 257
system info : X-87BL
Api-75- 2.57 Eubx
Boot Ver - 75
16 Mar 2008
Present Manu availe -
INSTALLATION (ACTIVE)
PARENTAL CONTROL (GRAY OUT)
cHANEL EDIT (gRAY OUT)
FACTORY SETTING (ACTIVE)
SYSTEM INFORMATION (ACTIVE)
SATELITE I am trying to scan are :
1) echo 9/T-13/KU and 2) echo 7/ku
LNB Type - Standard
LNB Local frequency - 10750
22khz - off
Diseqc # 1 also tried 2,3,4 no luck
Legecy SW - none
Skew - -45
TP (1) 11724 V20.000
Position Settings - USAlls - tried different settings but no luck.
satellite scan - all
LEVEL - 98%
QUALITY - 0%
AFTER EVEN BLIND SCAN RESULTS 0 program found
So thats all and look like I am damm since i did factory settings which may also cause more problem. Please justify why I lost parental control menue, where I should normally go choose dishnet and then Autoroll. Why I can bring back this option? Do you thinks my boot file is wrong then which is right one and where to get right one?
One last thing if I reset from back of the receiver display blink with number 6---7---5 then receiver goes to ON mode and thats all.
Please assist so I can move on. your assistance will be appreciated.
Saika
Username: Nydas
Post Number: 9349
Saika: Very good and detailed information.
1. Do User setup
2. Just set up Echo 7 (119w) - nothing else.
LNB Type - Standard (try ocs and dish-pro as well)
LNB Local frequency - 11250
22khz - off
Diseqc # 1 also try 2,3,4 as well
Legecy SW - none
Skew - -45
TP (1) 12224 V 20.000 (Try 12239 V as well)
Position Settings - USAlls - tried all
Do a Blind scan.
If no success, then install the genuine 256 or 254 BIN ([link removed]) and try as above.
Make sure you use Loader 27.02
The two grays WILL change to Active.
Username: Popol_vuh
Post Number: 42
I concur with Nalin - the local frequency for a standard LNB should be set at 11250, not 10750. That is your problem right there. Anyway just by selecting "Standard" in the LNB field the frequency should automatically revert to 11250. Tried a list with that setting a few days ago and had no signal...
Username: Phlyer
Ontario Canada
Post Number: 22
thanks so much nalin for the above info...for the longest time I could only get Nimiq after some person played with my unit. now I get Echo again
