What we have to convert 2500 to puff or any new file
Username: Adave
Post Number: 144
plz my 2500 frizing all the time any new file i am useing jw file what i have to convert to puff
Username: Kirankumar
NO Bashing
Post Number: 2136
dave,
sorry, i don't know much about converted receivers,but Nalin has posted details on how to do it a lot of times,just go back and look at some old threads,and if you still need help after that,post here again so someone can hopefully help you
Username: Nydas
Post Number: 9190
INSTALLING PUFF BOOT AND BIN
These instructions are for Pansat2500/FLU whether converted to b75 boot or not
DO NOT USE ON GENUINE PANSAT 2700 OR REAL CLONE PANSAT 2700
Preparation
1. Connect receiver to computer using a straight RS232 cable
2. Turn on racier and let it come to rest at ON or the last channel number
3. Save your current channel list.
4. If your channel list is more than 6 months old, skip all the above.
5. KEEP RECEIVER ON.
Loading Boot60
6. Start 2700 to 2500 conversion software by Chancysand.
7. Select Boot in the Loader software.
8. Select Boot60 from the distributed software.
9. With the receiver ON, click on Write.
10. Wait for write to complete.
11. KEEP RECEIVER ON.
12. You will see horizontal night riders. DO NOT PANIC.
13. Close the 2700 to 2500 conversion loader and
Loading Boot/BIN PUFF '" must use the 640K PUFF BOOT/BIN combo.
14. Start the BL 1.4 updater.
15. Select Chancy's or jvvh 253 boot/Bin 640K file. The file name must have the word PUFF in it.
16. With receiver ON, Select BIN in the Loader and start write BIN.
17. When it has loaded it will say BURN on the loader software .
18. DO NOT SWITCH OFF.
19. When BURN is completed, your receiver will reboot and sat P-U-F-F
20. Leave it on.
21. Wait till it stops PUFFing and says ON.
22. Now switch it off.
Loading latest PUFF BIN. This is the part to be repeated in future with newer PUFF BINs. You will always use PUFF BINs clearly labeled PUFF
23. In the BL update 1.4, select the latest 256 PUFF BIN and select BIN in the loader. Keep right hand on mouse ready to write.
24. Turn on receiver at the back using left hand and as soon as you see P (of PUFF) scrolling, click on Write with right hand.
25. Again wait for BURN to take place and then the receiver will reboot, go through the P-U-F-F cycle and rest with ON showing.
Loading Channels.
26. Now install the channels using channel master.
27. Disconnect from receiver and connect to your TV.
Do user set up and attend to autoroll.
28. First thing '" do a user setup including date.time, time zone and turn closed caption off.
Blind Scan if Channel list old or not available.
29. If your channel list is good, you may skip a blind scan, otherwise do a Blind scan of your sat '" just one sat first.
30. If keys do not autoroll, go into parental control (CAS menu) and click on 'Set Default key and wait for autoroll to load the keys. It takes about 2-3 minutes.
31. You must do switch Off and On at the back in between if things are not happening as they should..
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. Either b75 or PUFF
http://public.box.net/2500_full_kit
Username: Lklives
Post Number: 14664
Nalin Nyda
Username: Nydas
Post Number: 9144
Posted on Wednesday, March 12, 2008 - 07:06 pm:
LK is known to have given evidence against people posting at FTA sites. The evidence was given in Florida Courts.
Nalin...either provide the PROOF or LEAVE here...U have NO credibility anymore...and have been exposed as the malicious Liar you are with the intent of destroying this site and FTA..People like you are not wanted or needed here, as evidenced by the posts here..
Username: Nydas
Post Number: 9209
Preparation
Loading Boot60 '" only for new conversion to PUFF
Loading Boot/BIN PUFF-Only for new conversion to PUFF '" must use the 640K PUFF BOOT/BIN combo.
20. Leave it on.
Loading Channels.
Username: Luckjb
I followed the instructions Nalin posted, i had a 2500a not converted sitting here in dust for months and now its working like a charm it took me 10 minutes doing exactly what she says except for the first part :
20. Leave it on.
Loading Channels.
So i don't see how she can be a fraud ...her instruction did help me.
Username: G0bl1n
Will the PUFF convertion work on my lifetime classic na? If not what Will?
Username: Metallica
Post Number: 345
I think any receiver that can converted to 2700A will...
Username: Postergirl1
Post Number: 78
Preparation
20. Leave it on.
Loading Channels.
Post Number: 79
And for those who still haven't seen a thread or posts reguarding puff, I'll c/p a few hundred more times
Preparation
20. Leave it on.
Loading Channels.
Post Number: 80
Preparation
20. Leave it on.
Loading Channels.
Username: G0bl1n
Thanks I will try again. everything I have found on the net only talked about the FLU and said nothing about the Classic NA. so I did'tn know if they were the same or not. As you can see I an verry new to FTA and I have alot to learn.Thanks again.
Username: Nydas
Post Number: 9370
G0bl1n: There is no conversion available for Classic NA.
Please note that there is an imposter going by the name of Nasty Nalin - Username:Postergirl1, posting like me.
My posts will clearly indicate Gold member with over 9000 posts.
Username: Hangon
Post Number: 60
We love you Nalin Nyda, I always look for you for help.
Username: G0bl1n
Thanks Nalin Nyda! I'm Just looking for somthing that will work. I have ALOT to LEARN. Thanks Again!
