What BIN Files For DISH
Username: India101
Post Number: 31
i just wanna know what BIN files are working for DN for fortec converted to PUFF.
I loaded Chancysand PUFF Bin 256T and all i am getting is scrambled channel
please help
Username: Metallica
Post Number: 332
Krish...try to turn off your box from the back for a minute than turn it back on...if still don't work go and get the bin 257 just came out 3 hrs ago.
http://www.ftabins.net/forumdisplay.php?f=35
Username: Lklives
Post Number: 14750
VERY often when U upload a new file, your antenna receiver settings will change too inadvertently....always check them and do a REBOOT (rear switch off for 2-3 minutes) before and after U upload a new file..
Username: Nydas
Post Number: 9325
Krish. If you haven't sorted out your problems yet, I suggest you download from the following URL and study the instructions.
http://public.box.net/2500_full_kit
