9000hd problem.. need help
Username: Droy1
Huntington beach, Ca Orange
Post Number: 36
when I turn on the box it boots to the b-06 like it should then instead of going to a channel it goes ---- then it goes to like InIb
or 1n1b but on either one the b isnt complete. The b can look like a small t which i think it is. Can someone help me with this on what to do and what happened... Thx alot
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1046
Can you put the bin with USB?
Username: Droy1
Post Number: 37
no I cannot because the screen doesnt even come on
Username: Dimwitt
Post Number: 505
the language screen should be on the tv when --init-- is displayed on 9000
if no menu
C/P
Restore Dead Pansat 9000 units
This is a very simple way to restore any 9000 Hd unit if it is stuck on b-05,06,07
Download the factory bin and rename the file to API_FILE
Once you rename the Factory bin to API_FILE you can apply this to your usb memory stick alone in no folders
Step:1 Rename the factory bin to API_FILE
Step:2 Put the API_FILE on your USB stick in no folders
Step:3 Plug the unit in with the power off
Step:4 HOLD the Right button on the face plate with the USB Stick plugged in
Step:5 Turn the power on with the toggle switch wile you are still holding the right arrow
Step:6 API will appear on the screen you now can stop holding your right arrow
Step:7 it will say API,Succ,End
Step:8 If it doesnt work please re try the steps again
Username: Plymouth
Post Number: 1049
Darren i dont know if a loader for your box
you may try to download and install on computer this loader : VSPRO Loader - Firmware Updater ( Serial) on viewsatusa.com/support
and load factory bin with it.
before check in you origin packing if a cable and instruction is furnish.
If you need more info reply.
Username: Droy1
Post Number: 38
Then i should load the updated bin.. right and thats it? When i rename the file is it when i extract it to a file?
Username: Plymouth
Post Number: 1050
Oh it's a Pansat listen Tooter
Username: Droy1
Post Number: 39
Plymouth i got he factory bin on my desktop now i just have to put it on my usb stick and give it a try i guess. I want to thank all for help and continue to give all info..
thx darren
Username: Droy1
Post Number: 40
Tooter... What due you mean the language screen should be on tv... is there something im not getting here
Username: Dimwitt
Post Number: 506
init is displayed when all your saved settings are lost --like after a factory default.
you should have a menu screen ( select language ) on the tv , so you can set up the receiver and scan the sats your aimed at.
Username: Droy1
Post Number: 41
tooter i have no menu screen on the tv and the api file didnt work.. anything else we can try or due
