"Searching 4 Dish Keys" message
Username: Cover_point
Post Number: 13
Hi,
Can anyone help?
I have a 2500 converted to 2700. I installed the Jvvh_Fortec-Pansat_CanAm_256_(b75) BIN. But when I select any channel I get the "Searching 4 Dish Keys" message and it reaches 900% and continues.
I tried rebooting the box by switching off and ON the button in the back of the box.
Any ideas?
Thanks in advance.
Username: Nydas
Post Number: 9217
You might have to rescan.
Save or note down your antenna setup, if it is still there.
Do default setup
do user setup.
do antenna setup
do blind scan.
Username: Lklives
Post Number: 14676
Dish Network (0101) [Last update: Sat. Mar 15, 8:47 AM CDT]
86: F7 49 DD 11 E4 36 7C D0 F8 FC 18 98 F2 D5 F3 E8
96: C2 ED EE 89 50 60 82 D9 66 26 0D 45 AC E3 36 2A New
Username: Lklives
Post Number: 14677
Be patient and let the autoroll input them...or do it yourself manually...DN key change this morning..
Ignore the idiot named Nalin...bad info again by her..
Post Number: 14
Thanks both of you. It worked after searching for ~2000%
