Urgent Helppppps Please !!!!
Username: Deptrai_cachon
Post Number: 47
hi..I have VS Ultra ... I was trying to load new bin and my power went out .. now it won't turn on .
so it is burned , do I need new receiver .. or anything I can do to save it .. ?
any help guys ...
thank you in advance !!!
Username: Mc_sunny
Post Number: 1243
Get a "Factory Bin file" & transfer this data from the PC to the Viewsat STB using the standard Loader2 procedure...
Once the STB front panel goes to "0 0 0 0?, you may turn off the Viewsat STB...
Using Loader2, again find the "Current Bin file" to program your Viewsat STB using the standard Loader2 procedure...
Once the STB front panel goes to "0 0 0 0?, it is safe to turn off the Viewsat STB...
If you have a special "satinfo.sat" satellite file, use Loader2 and the standard data transfer procedure to transfer that data from your PC to Viewsat STB.
The Viewsat STB should now be back in good working condition...
If not, you've lost nothing by trying and should try this multiple times before giving up.
Username: Rtap
FL
Post Number: 2030
you probably loaded the wrong bin.
did you load this one pftausw-080311u.zip
Post Number: 48
sorry i;m very new to this ..
i tried to load bin pftausw-080311u.zip lastnight.. and it froze... so I turned off the main switch in the back ..
and now this is what happen
my vs is not turn on now ... when try to turn on the main switch in the back .. the light in front show "---- "
and the TV screen said " NO SIGNAL "
so how can I load the Loader2 .
.do I use the cable or usb >>??
will it work with the blank screen ??
and where can I get loader2 ??
Username: Rtap
FL
Post Number: 2032
try loading the factory bin then the new bin
Username: Lklives
Post Number: 14580
U have power...U just have nite rider lights..its a simple fix..
U need to go to a site that has files and the instructions to resolve your simple problem...theres a thread here listing other sites..
Post Number: 50
lk
what site ?
what thread ??
can u link me there please .. i;m very stuckk right now thanks
Username: Buyer2007
Post Number: 13
Thread: Best Satellite FTA Info sites
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 826
Ken go to viewsatusa.com/support.htm
download and install:
VSPRO Loader - Firmware Updater ( Serial)
and download :
VS2000 ULTRA Factory Bin File - V0132
open it and load it
do a hard reboot and load last bin.
If you loose your data, that because your box is need clear data, read it:
https://www.ecoustics.com/electronics/forum/home-video/459283.html
Good luck
Post Number: 51
plymouth or lk ..so do I need to load the factory bin or the loader2 ? ? or both ??
my tv screen is blank right now .. will i be able to load them by serial cable ?
Username: Rtap
FL
Post Number: 2040
ken go to viewsatusa.com get both factory file and loader there.load the factory file then load the current file thats it
Post Number: 52
ok ... i'll try it then i'll let you guy know ... thank you for all your help guys
Username: Plymouth
Post Number: 830
Ken
the loader is for install on computer and with it you load factory bin
if need info reply.
Username: Kirankumar
I will not b...
Post Number: 2100
Ken,
download the loader,you need this to download files to your receiver
next download factory file 132 and unzip it
hook up your receiver with cable to pc
keep receiver turned OFF
now open loader and bring the unzipped file into loader
now press pc to stb and turn your receiver ON
do Not do anything until the download finishes.
once that is done download latest bin and unzip it
again with receiver OFF open loader and bring that file into loader and press pc to stb and turn receiver ON
wait until it finishes
then turn receiver OFF and hook up to tv and connect all cables and turn receiver on
if you have any problems post here and i will give you step by step instructions
Username: Tsurat
Post Number: 10
I think one has to be careful when to install the remote fix bin for viewsat as I had the same problem. followed your instruction in this thread and it works fine now..thanks to all
Username: Plymouth
Post Number: 832
YES African it's true I forgot procedure
Ken after load factory bin.
You can use USB for download.
Username: Tgyoung1
Illinois U.s.a.
Post Number: 14
pansat 2700a going off and on scramble channels..?
Username: Lklives
Post Number: 14590
That is the simple NITE RIDER ---- dashing lights fix...it works on ALL receivers, regardless of make amd model...the only thing that will change is the loader and factory file U would use for other receivers...
Post Number: 53
african, turning the receiver on , you meant the main switch in the back ... right ? and it will show the dash ?? right ? b/c the power buttonin the front doesn't work right now
I will not b...
Post Number: 2103
yes you got it from the back
Post Number: 54
ok thanks....i'll try it and keep you update.
for all the people help me .. thank you very very much ...
i thought my receiver is dead for good ..
I will not b...
Post Number: 2105
Ken,
be patient and persistent,your receiver is NOT dead,do exactly as i have told you and you will get it working.good luck
Post Number: 55
anyone please help ....i try to load the factory bin using loader2 .. but it said the selected file not exeptable ..
what's wrong ??
i used viewsat ultra v0132
Username: Plymouth
Post Number: 835
Try VSPRO Loader - Firmware Updater ( Serial) From viewsatusa.com/support
Username: Plymouth
Post Number: 836
This is loader for Vspro but work fine for ultra.
Post Number: 58
that's what i used ....but when i pick the factory bin v0132 .. it said not exeptable
what else can I do ?
Post Number: 59
yes, but it's not exepting the factory bin
Username: Plymouth
Post Number: 845
Ok Ken try to download last bin directly
Post Number: 69
African , the reason i was having problem lastnite with the loader because i was using loader1 . downloaded from viewsatusa.com ( it didn't work with vsultra)
but i got the loader2 at ftatalk.com and it work .. my vs up and running !!
Username: Plymouth
Post Number: 876
Good news Ken
I will not b...
Post Number: 2120
I assumed you were using loader 2 as to your post,
but i am glad you got it working '
enjoy
Ken
Post Number: 55
Posted on Thursday, March 13, 2008 - 08:47 pm:
what's wrong ??
