Viewsat platium help/question ??
Username: Sunshine123
Posted on Friday, March 07, 2008 - 10:05 pm:
Copied this for help on a specific question..
Go to Code menu
Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider with F3
switch off 10 secs on back panel
and load last bin
turn autoroll on
Thats erase bad data in the box
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Do not intend any disrespect here but I copied these instuctions for help?
When the above instructions states "Delete this 3 provider with F3"
What do I do ??
I mean how do I do it?
Do I press a button on the remote and just delete it all??
As you can tell I am a rookie.
Thanks to all!!
Username: Kirankumar
I will not b...
Post Number: 2092
Why do you want to do this?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 786
OK african i'm here
Do you have problem like mention
Username: Plymouth
Post Number: 787
Leaf yes with remote orange F3
Thank you all for your help, the reason I need to this is because VS frooze up the other day turned off from the back and turned back on after 5 mins or so then got a no channel message on front of box. Check antenna setting and it said HISPAT ? It usaully says Echo star 9, went ahead and changed it back. Now I lost some HBO's ,ESPN, NFL Network, some adult channels and probally some other channles that I haven't figured out yet.
Why did I cahnge it because we have another VS box in the house so I went ahead and tried to set it up the way the other one is set up, which is working fine.
If anyone can help would very much apprecaite it.
Thanks
Username: Plymouth
Post Number: 788
Leaf my solution resolved problem with lost of setup sat . It seems to be bad data from 1 bin.
The only thing freeze is remote and display, but you do a hard boot with rear switch and all come back without lost of sat and channel info.
Just read it:
https://www.ecoustics.com/electronics/forum/home-video/459283.html
Thanks
Thanks for all the input will try and and give it a shoot
Will keep you all posted on how it works.
Thanks Plymouth
Username: Plymouth
Post Number: 794
Good luck Leaf and thanks for reply
