Username: Juchito97 Post Number: 40 Registered: Jan-08
Saturday, March 15, 2008 - 16:46 GMT i just moved and try to istanll the dish my self, on 119w i got quality 86% and strenght 97% but in 110w i got quality 0% and strenght 79%, what i do????
Username: Saqeeb9000 Mughe dard rehta hai, ...,
Mujhe bhook ...
Post Number: 2837 Registered: Oct-07
Saturday, March 15, 2008 - 16:51 GMT you are making it confusing..... are u moving dish from 119 to 110.. or 110 to 119.. or you have 2 lnb's ..
Username: Juchito97 Post Number: 41 Registered: Jan-08
Saturday, March 15, 2008 - 16:55 GMT i got 2 LNBs
Username: Abj Post Number: 543 Registered: Feb-06
Saturday, March 15, 2008 - 16:55 GMT should give more info on your antenna setting in your receiver. what port is your 119 commited to ? 110 commited to ?
Username: Juchito97 Post Number: 42 Registered: Jan-08
Saturday, March 15, 2008 - 16:59 GMT all settings are ok, path is enabled and auto roll is on, i thing my problem is that i didnt intall the dish correctly, thats why i mention that 119w quality was 86% and strenght 97% but 110w quality is 0% with strenght of 79%.
Username: Kirankumar NO Bashing
Post Number: 2148 Registered: Oct-07
Saturday, March 15, 2008 - 17:03 GMT look you need to adjust the skew on your dish,go to www.dishpointer.com for exact instructions and once 119 is lined up good,also you need to post your antenna settings for both sats so we can take a look at it,post it before you do anything else
Username: Juchito97 Post Number: 43 Registered: Jan-08
Saturday, March 15, 2008 - 17:12 GMT sattelite name: echostar 7(119w) transponder: 12224/v/20000/5/6 LNBfreq: 11250 LNBtype: OCS-DP 22KHz: on Diseqc number: LNB1 Legacy sw: off Motorised sys: none ecostar 6,8 (110w) 12224/v/20000/5/6 11250 OCS-DP on LNB2 off none
Post Number: 2150 Registered: Oct-07
Saturday, March 15, 2008 - 17:16 GMT so you have 119 on port 1 and 110 on port 2, do you have a switch installed outside and if so have you hooked up 119 to port 1 and 110 to port 2? post
Post Number: 2151 Registered: Oct-07
Saturday, March 15, 2008 - 17:19 GMT also check the type of lnb you have if it is not dispro then set your antenna settings lnb type to single
Username: Juchito97 Post Number: 44 Registered: Jan-08
Saturday, March 15, 2008 - 17:23 GMT i was using a twin lnb dp, now im using a twin LNB dp plus, this maybe causing the problem??
Username: Juchito97 Post Number: 45 Registered: Jan-08
Saturday, March 15, 2008 - 17:25 GMT on the antenna setting i got the right setting i have 119w on LNB1 and 110 on LNB 2 now is telling me that only found 110w, so why is not finding 119w
Post Number: 2152 Registered: Oct-07
Saturday, March 15, 2008 - 17:25 GMT do you have a switch installed outside?
Username: Juchito97 Post Number: 46 Registered: Jan-08
Saturday, March 15, 2008 - 17:27 GMT no
Post Number: 2153 Registered: Oct-07
Saturday, March 15, 2008 - 17:29 GMT ok now we are getting somewhere, how many cables coming out from dish?
Username: Juchito97 Post Number: 47 Registered: Jan-08
Saturday, March 15, 2008 - 17:32 GMT on the antenna setting the first one on the list is echostar110 and the second one is echostar119, i got 110 in LNB2 and 119 in LNB1, if i take my stb to my friend house with this setting work 100% so why does not want to work here, once again the only diference is that he got the dual LNB DP and i got the dual LNB DP Plus, also if i go to antenna setting and go to the number two in the list that is 119w it got quality and strenght of 90% but it say that found 110w, thats wrong it got to be 119w
Username: Juchito97 Post Number: 48 Registered: Jan-08
Saturday, March 15, 2008 - 17:32 GMT only one cable straight to the stb
Post Number: 2154 Registered: Oct-07
Saturday, March 15, 2008 - 17:34 GMT ok you are not answering my question,how many cables do you see coming out from your dish on the roof. 1 or 2 ?
Username: Juchito97 Post Number: 49 Registered: Jan-08
Saturday, March 15, 2008 - 17:38 GMT 1, only one cable is coming from the dish, only one cable is coming from the LNB, and it go straight to the reciever.
Post Number: 2155 Registered: Oct-07
Saturday, March 15, 2008 - 17:42 GMT ok bring up 110 on antenna settings and select lnb 2 and see what happens
Username: Juchito97 Post Number: 50 Registered: Jan-08
Saturday, March 15, 2008 - 17:52 GMT African thanks alot but i need to go to the airport, later tonite i will continue with this problem.
Post Number: 2158 Registered: Oct-07
Saturday, March 15, 2008 - 17:55 GMT if that did not work then go to www.dishpointer.com and look at specifications,i think everything is good but you might have to adjust your scew a little
