Fortec Converted
Username: India101
Post Number: 29
I just wanna know what dish network files are working for Fortec Converted to Pansat2700.
Username: Ustaad_hc
Post Number: 567
if you convert fortec to pansat it mean its pansat so pansat is up .you only need pansat latest bin. thats it.
Username: Nydas
Post Number: 9132
Pansat Converted to 2700 DOES NOT use 2700 files. You have to use special conversion files.
If your system info says b75, or b75 shows up when you switch on, use a jvvh_254 or jvvh_254_Nkk bin
There is also a Lothario_254 BIN
If you have installed PUFF boot, it will say PUFF in the system info and also when you switch it on. You will need to install jvvh_PUFF_254 BIN or CS_254T_PUFF_lightning BIN.
Look at this url, download the instructions in both sections (b75 and PUFF) and read.
http://public.box.net/2500_full_kit
Username: Nydas
Post Number: 9133
The above applies to Fortec converted as well.
Username: Elvirm
Post Number: 29
Nalin, I have fortec converted to pansat, and now I don't have dish, bev either. Do you know what is going on?
Username: Nydas
Post Number: 9154
Just look two posts above and get all the files and instructions - b75 or PUFF.
Then <b>READ</b> the instructions and decide what you need to do.
