Add channels after puff conversion
Username: El_che
Post Number: 18
hi all, I converted my clone pansat2500 - 2700 and now to puff version. I loaded the last puff bin and everything works great except for my channels. I did a powerscan on echo7 and 8 and all I get it's the sames 120 channels 2-3 times. How can I get all channels only once? What settings do I have to change ?
Echo8.10/Ku :
LNB Type ; standard
Lnb local-freq. ; 11250
22kHz ; off
Diseqc ; off
Legacy SW ; None
Skew ; -45
TP ; [1] 12224 V20.000
Positionner Setting ; Disable
Satellite Scan All
Level ; 77%
Quality ; 0%
I have a Dish500 dish with 2 lnbs.
When I put TP to [2]12239 H 20.000, quality goes to 92%.
What's wrong on my settings.
Thanks
Username: Lklives
Post Number: 14534
every time U do a blind scan, it duplicates all the channels again..just do sat scans of each satellite independently...
to remove all the channels, just do a factory default/reset...and do 2 sat scans..110-119...reinput CORRECT antenna settings...and do a reboot
U need 119 (echo 7) on disque 1...and 110 (echo 8.10) on disque 2...using any Dish 500...theres 2 LNB's for 2 sats..
Username: El_che
Post Number: 19
I need to put 110 where's diseqc ?
Username: Nydas
Post Number: 9152
Abe:
Echo8.10/Ku :..............Echo 7
LNB Type ; standard........try osc or dish pro in both
Lnb local-freq. ; 11250....11250
22kHz ; off................off.
Diseqc ; off or 2.......... 1
Legacy SW ; None........... 2
Skew ; -45................. -45
TP ; [1] 12224 V20.000..... 12239
Positionner Setting ; Disable/Disable
Satellite Scan All......... All
Do Echo 7 first with a Blind scan and 110 totally unrecognised. Use Echo 7 setting as provided above on the right.
Then disable Echo 7 and do echo 8.1 using those setting with disEqc switch off or set to 2.
For future, please remember, that when you have working system, you write down your settings and keep them avaialble for rescan.
Username: Flu_guy
Post Number: 67
Nalin:
If I might make a suggestion...
When you do tables, use the courier font like this:
Because it is non proportional the columns will come out correctly, just the way you see them in the editor and your tables will look much tidier.
Htiek
Username: Nydas
Post Number: 9158
Htiek: Your advice well taken. I have a surprise for you - soon.
Username: Flu_guy
Post Number: 68
Thanks, I can't wait!
Htiek
