New member Username: Smokie2177Van buren, Arkansas Usa Post Number: 1 Registered: Feb-08 | can someone check it and repot ASAP PLEASE IM NOT @ HOME! FUTUREFTA |
Bronze Member Username: NenadsPost Number: 25 Registered: Jan-08 | No I'm pretty sure thats the old 250 one. I downloaded it the other day. |
Gold Member Username: NydasPost Number: 8554 Registered: Jun-06 | New BINs are out at htttp:// PANSAT (_.-**-.****Happy New Years With Many More Pirate Files For 2008****.-**-._) Current Files: - Pansat 9200HD [Dish Up - Bev Up]: Download - Pansat 9000HD [Dish Up - Bev Up]: Download - Pansat 250SM [Dish Up - Bev Up] : Download - Pansat 2800A [Dish Up - Bev Up] : Download - Pansat 6000HXC [Dish Up - Bev Up] : Download - Pansat 5000HXC [Dish Up - Bev Up] : Download - Pansat 3500S/SD [Dish Up - Bev Up] : Download - Pansat 2700A [Dish Up - Bev Up] : Download I just downloaded BIN 253 for Pansat 2700 and 369 for 3500 |
Gold Member Username: NydasPost Number: 8555 Registered: Jun-06 | New BINs are out at htttp:// PANSAT (_.-**-.****Happy New Years With Many More Pirate Files For 2008****.-**-._) Current Files: - Pansat 9200HD [Dish Up - Bev Up]: Download - Pansat 9000HD [Dish Up - Bev Up]: Download - Pansat 250SM [Dish Up - Bev Up] : Download - Pansat 2800A [Dish Up - Bev Up] : Download - Pansat 6000HXC [Dish Up - Bev Up] : Download - Pansat 5000HXC [Dish Up - Bev Up] : Download - Pansat 3500S/SD [Dish Up - Bev Up] : Download - Pansat 2700A [Dish Up - Bev Up] : Download I just downloaded BIN 253 for Pansat 2700 and 369 for 3500 |
Gold Member Username: NydasPost Number: 8556 Registered: Jun-06 | For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest files BL253T_Lightning_serial.bin . Some jtag files are also included. The full kit is in full_kit253A.zip or later. Download and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file. Also available separately in All_253.zip file with all the conversion 253 BINs released so far. http://public.box.net/2500_full_kit |
Gold Member Username: NydasPost Number: 8560 Registered: Jun-06 | BL_253T_lightning for converted 2500/FLU to 2700 working fine on DN. Do not use on Genuine or clone Pansat 2700. |
Bronze Member Username: CanadiandudePost Number: 17 Registered: Jan-06 | Nalin on Genuine pansat converted to flu..which bin should i used...will X87BL..080225..B75...253..API Work or BL253T Lighetning will work for my fortec star FLU i know jvvh works,..but if i use that on pansat FLU than remote wont work...please assist |
Bronze Member Username: CanadiandudePost Number: 18 Registered: Jan-06 | Nalin on Genuine pansat converted to flu..which bin should i use...will X87BL..080225..B75...253..API Work or BL253T Lighetning will work for my fortec star FLU i know jvvh works,..but if i use that on pansat FLU than remote wont work...please assist |
Gold Member Username: NydasPost Number: 8565 Registered: Jun-06 | For Genuine Pansat 2700 use x-87bl_080225_b75_253_api.bin For Genuine Pansat 2700 clone, manufactured as 2700 clone, use Pansat-C 2700 253v1 TiVo.bin For Pansat2500, Pansat 2500 clone, Fortec Ultra, convert first to work-alike of 2700 and then install BL_253T_Lightning_serial.bin, or jvvh_253_nkk.bin or p122654_253_AIO.bin The last mentioned three BINs are available at: [link removed] http://public.box.net/2500_full_kit |
Bronze Member Username: CanadiandudePost Number: 20 Registered: Jan-06 | For converted FortecUltra it is fine. But if i use jvvh for my converted pansat..than remoted doesnt work.Last time for this reciever i ued lothario_252...Wat is replacement bin for lothario 252 this time |
Gold Member Username: NydasPost Number: 8569 Registered: Jun-06 | X Factor: Look at the post above yours. |
Bronze Member Username: CanadiandudePost Number: 21 Registered: Jan-06 | i did..but when one is not sure it is always wise to ask some one who has better knowledge..and you do Nalin...Thanks |
