check that the unit is connected to the power outlet first and then check the back switch. then get the DBPSW-080222X Bin and program the box. If it doesnt work, then its dead.
Sam, open the box,make sure the cables to the switch are tight,then make sure the screws that hold the power board down are tight,don't tighten too much or you will break the board. now check that the cables from the power board to main borad is clipped in tight.then switch box on,if it works load factory bin first then current bin,let me know how it goes
Sam, just try what i said,make sure the back switch is OFF and main plug in wall is removed,also do not hook up box to tv,until you see clear 00.00 on front panel
African, I truly thank you for your following up on this matter. When I turn the power switch on from the back, the red light shows up for a second and then goes away.
that means that there is a loose power connection somewhere,take you time and check all connections from the time the cable comes into the box. also there is a cord with multiple wires going from power board to main board.unhook the plug at the main board and leave it out for a while then hook up. make sure the box is turned off all the time and unhook sat coax if it is hooked
also can you check the color of the power board if it is white it is genuine,if it is brown it is a clone,for a clone you will not be able to get it working,sorry
Sam did you try to download bin with RS-232 cable and wich bin . My ultra dead this morning and the only bin who ravive my box is dec 14th 2008 the other have a virus (i thing) If you have a light it's good with loader put this bin, you prepare for load, send and put on rear switch . that take 10-15 minutes to load, the box reopen itself. Good luck Reply please
