HELP Write failed
Username: Trina15
When trying to download bin I get message write failed
used blacklist 1.4
I have pansat converted 2500a to 2700 original
have downloaded bins many times with no problems
what am I doing wrong
thanks
Username: Jwl1
Post Number: 186
Mary--sounds as if it is a timing issue--meaning not switching the back on at the right time. Make sure the back switch is off--then hit write--and flip the switch on.
Just keep trying, you'll get it sooner or later, if is a timing issue.
Username: Trina15
I dont think its a timing issue I tried many times still cant download bin. I never had a problem downloading a bin before
Username: Rescate
VENEZUELA, M...
Post Number: 235
I had the same issue:
Then I reconverted again flashing with the j27_205_1.bin << Remember after this one you need to wait for two or three minutes to let the reciver reboot.
then flashing the latest bin:
Jvvh(F7)_Fortec-2500-Pantec_250.bin
then downlading my personal channel list (as a 2700 channel list, with channel master).
Now is ok, all channels UP
Username: Trina15
I just need to reinstall bin j27_205_1.bin and than install the latest bin? Nalin is this right. What about if I get Write failed whwn I try to download bin j27_205_1.bin. Thanks
Username: One_eye_jack
Post Number: 398
Mary
Use Loader FortecStar STB v4.0 By Jihad
and Flash with Bin CS_250T_Lightning_100t_Series_serial.zip
http://ftabins.net/showthread.php?p=130762#post130762
Username: Nydas
Post Number: 8211
If you can't load the
j27_205_1.bin
Use the "revert to 2500" method and go back to Boot 60, load 294T and then start all over again.
Also look for loose cable connection or forgetting to connect - both these stupidities have occurred to me.
Username: Trina15
Nalin
I tried to revert to 2500 and boot 60 bin
I get the message "FLASH UPDATE FAIL" Thanks
Username: Nydas
Post Number: 8215
You have to use the Chancy special 2700 to 2500 folder and then use his special reversion loader.
