B3v????
Username: Chilli
Post Number: 78
Anybody having any luck getting b3v on their pansats with the latest bins???
Username: Free_tver
Post Number: 54
for the last bin (249 for 2700) all that was and is still needed was to leave on the channel that you wanted for up to 2 hours and then the picture would magically come in after the long wait of scrambled or bad channel. once the picture comes in you can change channels within the same transponder with no problem but changeing to a different transponder would cause the wait to start over again. so be sure to set it to the channel you will look forward to watching for at least a good amount of time. i am unsure if this is good practice for the newest releases.
Username: Carburante
Post Number: 31
any luck with an old bin?
Username: Free_tver
Post Number: 57
the luck was explained in the post above yours
Username: Sachyadeewana
Post Number: 16
anyone know if the 250 bin also works on B3v as the 249bin? i.e. one channel on one TP?
