Missing channels on ViewSat
Username: Deptrai_cachon
Post Number: 30
hi guys.. I have viewsat ultra.. using dn echo 8,10 (110 W) .. and couldn't get any ESPN chanenel or CNN .... I couldn't use
echo 7 (119 w) because I was told it blocked by other house. ...
ohh one more thing ...most of the channels i got are double or tripples..
how can I fix this problems .. please help me !
thanks
Username: Madflea168
Post Number: 256
I have read similar posts out there, I think it has something to do with the dn's ecm to block the vs's blind scan or something which cause this problems.
go search.
Post Number: 259
you posted this twice.
https://www.ecoustics.com/electronics/forum/home-video/449511.html
Username: One_eye_jack
Post Number: 384
Ken
If you can point to Echo 8/10 @ 110.o*W
you shouldn't have any problem with Echo 7 @ 119.
Move the Dish, put on your roof or a pole.
Double Channels
Pull up Channel Edit and delete the double channels.
