Viewsat ultra 2000 loader
Username: Kirankumar
Kenya
Post Number: 1600
guys,
a friend gave me his vs2000 ultra to fix,it has no remote,but i want to try and factory flash it,any ideas,also what loader do i use,because i want to use a cable and not usb.
the unit looks like dead right now,but would be good to get it back to life
Username: Saqeeb9000
Post Number: 2311
http://forums.d*sstester.com/vbb/showthread.php?t=41717
(remove *)... its called loader 2
if you can't even turn it on.. it means its dead...
Post Number: 2312
and for factory bins..
[link removed]
Kenya
Post Number: 1605
thanks sada
what kind of cable nul or straight?
Username: Steph_raven
Cartier is my boy toy!..., U wanna play... Canada
Post Number: 344
i used null in vs ultra to load the ultra fail a few weeks ago
Post Number: 345
btw if it's dead you might wanna try the fail fix too
Kenya
Post Number: 1607
Stephane
how do i do that,
by the way i am not stupid,but i have never worked with viewsat boxes,i was c00lsat guy.just trashed my dead c00lsat,and promise never to buy another one,because i found out door stoppers are $ 1.25 at home depot ,so why spend $ 189 for the same sh!t
help me out here with viewsat
Post Number: 346
i didn't judge you. did you download the fac bin or ultra fail fix and loader 2?
Username: Johnny_blaze74
I have a vs extreme the last few files that i uploaded have not worked. all it does is autoroll the preview channels come in right away but all other channels are blacked out and just rolling. I did a factory reset and reloaded the factory bin then loaded the latest file still not working. others are using the same file with no problems. Any ideas would be great
Thanks ahead
Post Number: 347
Jinely, you should start your own thread...check your settings, lnb type, connection....
Kenya
Post Number: 1610
Stepane,
i downloaded fac file,but but nothing is happening.what is an ultra fail fix? what do i do with it and where do i get it?
Post Number: 2316
african can u see anylights on box.? like does it turn on?
Post Number: 348
get it at any site you trust..it's clearly indicated as ultra fail fix....all websites have it. live, ftatalk etc
you have to get the loader 2 as well. plug box in,turn box off via switch. plug the cable. start the loader 2 software. press open file. choose the main.pgm. from the ultra fail fix zip, the press the pc to stb. turn rec'er on...it should go from there.
Kenya
Post Number: 1612
sada
sometimes the lights come on .so the sucker has some life in it
i just don't know how to do the CPR on this little sucker
Stepane,
i am going to look for fix,thanks for helping out
Username: Nydas
Post Number: 8186
VS Ultra FAIL FIX
[link removed]
Viewsat Ultra- Null Modem and USB Memory Stick
Username: Metallica
Post Number: 118
Afrian try this..Kevin Ultra came back alive this morning...Good Luck.. it C/P from Brucel
How to bring back your Ultra from the Dead >moved, Clyde<
This is basically a n00b proof guide on how to bring back your Ultra from the dead. I basically had this problem and through some research and help from you guys i was able to accomplish it. So here is how it goes.
First off don't panic and think calmly. There are some things you are going to need. And these are : Software, Cables and the ability to follow instructions.
Software:
-Latest factory file. You can find this either in the VS Ultra files menu on this site or by going to viewsatUSA.com (I used 1.31)
-Loader program (I used VS loader), instructions on how to use the program are included when you download.
-The latest fix, as in the .pgm file you normally download.
Cables:
-Null Serial Modem cable (usually included in the box)
*Note* If you don't have a serial port on your computer (problem with most new computers) you can purchase a serial to usb cable from bestbuy. I used the Dynex one, there were no drivers included so your stuck getting it from dynexproducts.com
Very important to know what com port the serial cable is on. Making sure that the cable is plugged in, go to control panel > system > hardware > hardware manager and look for the "COM" tab, and it should be listed there.
-Follow any instructions included very carefully as you will be writing to flash memory, and trust me you don't want to screw up there.
Procedure:
1) Unplug your sat box and hook it up to your computer via serial cable.
2)Load the latest factory file through Loader. *THIS HAS TO BE DONE ON YOUR COMPUTER FIRST!*
3)Either unplug from computer and go back to tv and load latest fix via usb, or load latest fix through Loader.
4) Complete
Closing Notes:
Although this may seem simple enough, i cannot stress the fact of doing everything properly. Any slip up could cost you your box. Always let the install complete and wait till the sat box turns off, comes on again and says "End". If you interrupt power at anytime through the install you could be in trouble again.
I may have forgetten to add anything so if you have any questions or additions, Post away
this is for ultra dont use the files for the ultra use the file for your box and this might get you up and runing hope it helps you and you can get all this info and more at crazyfta dot com enjoy and you will not get ancer like that ancer you got from ftakeys and wee have live chat to help you better
Kevin
Username: Explorer
Posted on Friday, February 15, 2008 - 11:53 am:
It's Alive!!! I sincerely appreciate all your help Metallica!
I will be joining crazy fta dot com ASAP!!
Post Number: 2318
''Kevin Ultra came back alive this morning...Good Luck.. it C/P from Brucel ''
if your viewsat is dead.. nothing will work untlil you gtag ur reciever..
Kenya
Post Number: 1614
Kenya
Post Number: 1616
i tried everything,it just says resending ,and every time i switch the receiver on it has different kind of lights.i guess i have to trash this as well and go back to my cable tv
Username: Metallica
Post Number: 119
Hey sada..kevin Ultra not really dead it still have of light in it...and btw you can't gtag any VS..
Afrian said sada sometimes the lights come on .so the sucker has some life in it
i just don't know how to do the CPR on this little sucker..
and i don't think it dead when Afrian said it still have some light...try it out you have nothing to lose..
Post Number: 349
African...try different cable...it's important to switch unit off via back switch b4 starting the download process. start downlaoding..then turn unit on via switch...like hard boot
Post Number: 350
African, try changing com ports...if you have 2 comports. either in the loader interface or unplug & replug in the other com port
Post Number: 2324
african if you listen to me and buy nfusion.. u don't have to worry about this b.s
there are two problems with ur rec.
first you said its sending signal so what i am getting its sending signals.. so if it does.. that means its not dead...
if you are rec signals like 1...10% etc..
then there might be problem with your loader.
extact the loader fully and use it from where you save it .no shortcuts,
or check cable...
Kenya
Post Number: 1617
ok how do i change port
Post Number: 351
how many com ports on your pc?
Post Number: 352
Loader2 User Guide
"Loader2" can download the firmware from PC to STB.
1. Install "Loader2" to your PC.
2. PLUG OUT YOUR STB FROM OUTLET.
3. Connect "NULL MODEM CABLE" between PC and STB.
4. Run "Loader2" on PC.
5. Run the "Tool->Configuration" menu and select serial port what you use.
6. Press "Open File" button and select the file what you want to download.
7. And then press "PC->STB" button.
WHEN ZMODEM WINDOW IS APPEARING, PLUG IN YOUR STB.
8. Then selected file will download from PC to STB.
9. When download is complete, you can see below message.
When you see this dialog on PC, STB will start to write flash memory.
Please wait until STB automatically reboot.
Post Number: 353
there's a pdf file when you download the loader 2 software and the info in the above post is there...with pictures...WOW!! lol
Kenya
Post Number: 1618
not working
Username: Madflea168
Post Number: 260
the ultra fix is for the ultra showed '----' when turn on, if not, I doubt it still alive, there are some other saying try to switch on/off with the back switch several times might get it back, somehow, did not work on my xtreme, it showed different wierd thing on the panel on every try. I dunno about ultra, don't have one, but you can play with it.
good luck.
Username: Vic123
TorontoCanada
Post Number: 71
african ur reciever is dead ok dead trash it...
i had the same problem no1 could fix it n i mean no1 ...the receiver you have was a clone and you or ur friend loaded a fake file in it...trust me its dead
Username: Nydas
Post Number: 8190
For information on Viewsat clones, files, clone repair, etc., go to:
[link removed]
Kenya
Post Number: 1619
is there a was of telling if it is a clone?
Username: Nydas
Post Number: 8192
Look at Viewsat clone discussions.
[link removed]
Kenya
Post Number: 1620
vic
Username: Vic123
toronto canada Post Number: 71
Posted on Saturday, February 16, 2008 - 09:57 am:
vic,
i fixed it
Kenya
Post Number: 1621
Guys,
thank you all for helping me last night.
as i have always said this is a hobby and you have to be persistent.it was a very simple fix,
but i was frustrated.
this morning i checked and it is not a clone,thanks Nalin for that link.
what i did is opened the box,which someone had already done,because i saw nuts missing,anyway after spending about 1 hour with a magnifying glass,could not find anything,then i noticed the wires to the switch were a bit loose.got might pliers and squeezed them a bit and ,the little sucker works like a charm.
Stepane,thanks for you help last night and also Mad Flea
Username: Vic123
TorontoCanada
Post Number: 72
African im glad u got it fixed...u still have a clone receiver..
enjoy till it gets completely dead on you..have fun :d
Kenya
Post Number: 1622
it is not a clone,
there is a comparison chart at ftatalk and i went through it this is genuine
[link removed]
and it is not mine,belongs to a friend who is a newbie i got to go and set it up for him
Post Number: 2334
african really glad to hear that ur problem is solved...
Post Number: 354
np African..glad u got it to work... it's a great rec'er. i really enjoy it.
