BEV down?
Username: Nydas
Post Number: 8095
Reported down on Sonicview, Pansats and Viewsats
Username: Nydas
Post Number: 8096
Conaxsat Duo/Trio : Bev & Dn .... Up !
dn wide open use 0210_1159 patch.
bev wide open use 0131_0175
Username: Nick000000
Montreal, QC Canada
Post Number: 27
It Is down on my Pansat 2500 to 2700 clone
Username: Nydas
Post Number: 8099
RECEIVERS UP ON AFTER BEV'S NEW ECM (applies only to BEV):
1) Conaxsat using 0131_0175 patch
2) Nfusion up via IKS
3) CaptiveWork p 1.72
Username: Realtorkim
INDIANA United States
Post Number: 43
Thanks as Always Nalin,
Have Pansat 2700, Flu and Viewsat. I knew there had to be another one better.
Sure never thought fta would be my next learning goal.
Thanks I'm sure this not the right thread to ask. I'll look for info..
What is your opinion on best FTA box
to purchase?
Won't critic you later. ha ha
Username: Nydas
Post Number: 8110
If you want to remain in the general FTA group, then Sonicview 4000 remains a good choice at about $170. It has USB input.
CaptiveWorks 600Premium is a good low cost choice because of their rapid response to ECMs.
Unique solutions like Nfusion and IKS based solutions remain a good bet. I suggest you read some threads here in th subject.
Username: Jaye50
Post Number: 80
bev just came back up on my converted flu....i had left it on cause i was too lazy to turn it off....and it just came back up....
Username: Brucelee
Beverly Hills, California United States
Post Number: 141
Is that what's happening? You have to leave it on autoroll for a couple of minutes and it should work? I have a VS Plat. I'll try it out.
Username: Jaye50
Post Number: 81
mine was on for more than a couple of mins.... lol....it was on to a black screen for about three hours.....since i came home.....guess it finally rolled....cause it's on now tho.....
Username: Brucelee
Post Number: 142
You said it finally probably autorolled. Do you have the latest keys for BEV? I'll manually put them in rather then having it autoroll automatically.
Username: Jaye50
Post Number: 82
the keys don't seem to have changed.....at least it's still showing me the same key that was in previously.....it will sit on the scrambled channel screen for a couple of hours....and then suddenly the channel will come in....
if i try to change the channel it will go back out.....back to scrambled screen.....sit for another couple of hours and then come in again....
i've got it on space.....and i'm keeping it there.....
Username: Nydas
Post Number: 8112
Viewsat Bev fix available now at:
[link removed]
[link removed]
