New member Username: JawallaOrlando, FL USA Post Number: 4 Registered: Oct-06 | Pansat Clone 2500 -> Converted to 2700 Load current bin file. Conversion, loading bin went well. B3V signal strong on Nimiq 2. Channels are downloaded fine but "Scrambled or Bad Channel" on each when I try to view. Was working as PAnsat 2500 clone on Dish in Florida. --------------------------- I loaded the 247 by Lothario bin and got the same "Scrambled or bad Channel" I just loaded the jvvh248 pansat remote bin...same. What am I doing wrong? |
New member Username: JawallaOrlando, FL USA Post Number: 5 Registered: Oct-06 | When I go in Parental control, under CAS, I am not seeing B3V. Before converting to 2700 and B3V, I had DN and I used to go to Nagravision2 and set the DN keys? |
Gold Member Username: NydasPost Number: 7919 Registered: Jun-06 | You don't need to set any keys manually. 1. Do default 2. Do User setup including date/time. Set closed caption off 3. Do Dish setup. Go to Echo 7 and do setup 4. Do power scan 5. Do antenna setup for Echo 8.1 and power scan. 6. do other sats in th esame way 7. When you see TV, turn autoroll off. |
New member Username: JawallaOrlando, FL USA Post Number: 6 Registered: Oct-06 | After reading a few archived posts I did a "Set Default Keys" a number of times and it worked! However, I am not getting the Indian Channel and especially CBN for cricket? I can get all PPv and Adults. The sat I am pointing to is Nimiq2 at 82. |
Gold Member Username: NydasPost Number: 7924 Registered: Jun-06 | You should get B4UMU on TP 2 and other Indian channels on TP4 and TP5. Do a specific scan. http://www.lyngsat*com/packages/expressvu2.html |
New member Username: JawallaOrlando, FL USA Post Number: 7 Registered: Oct-06 | Nalin, this does not work. I scanned all the likely TP's and same. No CBN. Please help. I need cricket. |
New member Username: JawallaOrlando, FL USA Post Number: 8 Registered: Oct-06 | Still missing CBN channel!! |
Silver Member Username: One_eye_jackPost Number: 345 Registered: Nov-07 | Jawalla Nimiq 2 @82.o*W only scan this (tp4) Freq. 12268 H CBN Channel 730 |
New member Username: JawallaOrlando, FL USA Post Number: 9 Registered: Oct-06 | When I scan TP 4 Freq 12268 H I get only 3 channels - $11 Star $12 Space $13 VuP32 |
New member Username: JawallaOrlando, FL USA Post Number: 10 Registered: Oct-06 | I noticed when I do a Satellite Scan it goes to 60% then starts saving. Is this normal? or this may be the the cause of my problem? How do I delete all channels and do a full scan all over? |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 11 Registered: Oct-06 | Actually I get up to channel 580 RAI!! Please help. |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 12 Registered: Oct-06 | Can someone please respond When you scan TP 4 Freq 12268 H what do you get? |
Gold Member Username: KirankumarKenya Post Number: 1324 Registered: Oct-07 | who installed your satellite? seems like it might need a bit of adjustment |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 13 Registered: Oct-06 | Did it myself. |
Gold Member Username: KirankumarKenya Post Number: 1328 Registered: Oct-07 | Jawalla, you will have to get someone watch the tv while you make very slight adjustment to satellite until you get good signal |
Gold Member Username: RtapFL Post Number: 1826 Registered: Jan-07 | or just get a satfinder at a sat local store.easy to use |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 14 Registered: Oct-06 | I am getting 92% signal strength and I do have a sat finder that I am using. I am getting all other channels. |
Gold Member Username: KirankumarKenya Post Number: 1333 Registered: Oct-07 | I heard some channels have moved from 82 to 118.7,i don't have bev but can someone confirm tat they are getting cbn on 82? |
Silver Member Username: VittuPost Number: 142 Registered: Oct-07 | African, you mixing not only 2 birds but also 2 providers. 82 is BEV and 118.7 is Charlie |
Silver Member Username: VittuPost Number: 143 Registered: Oct-07 | Dish moved channels from 121 to 118.7 |
Gold Member Username: KirankumarKenya Post Number: 1335 Registered: Oct-07 | vittu, sorry my bad just got confused |
Silver Member Username: VittuPost Number: 144 Registered: Oct-07 | Don't you have the option like power scan or blind scan or similar?? try that |
Silver Member Username: VittuPost Number: 145 Registered: Oct-07 | you can also try uploading a channel list. This might help |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 15 Registered: Oct-06 | I tried power scan and blind scan. How do I upoload a channel list? I tried doing a search on this forum but got little info. |
Bronze Member Username: PlymouthQuebec city, Quebec Canada Post Number: 46 Registered: Jan-08 | Normally this is in the bin |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 17 Registered: Oct-06 | My woe continues as India vs Australia ODI plays again tonight! Still no CBN. |
Silver Member Username: DimwittPost Number: 403 Registered: Aug-06 | CBN - 82W - TP 12268 |
Bronze Member Username: JawallaOrlando, FL USA Post Number: 18 Registered: Oct-06 | Tooter, When I scan TP 4 Freq 12268 H I get only 3 channels - $11 Star $12 Space $13 VuP32 |
