Sv4000 freezes as deleting unwanted channles ....
Username: Lomna
Post Number: 115
When I deleting unwantd channels sv4000 freezes. It happens only with sat 148. All others sats I don,t have any problem with.Am I doing something wrong?
Username: Nydas
Post Number: 7931
Use Channel Master. Delete in CM and then load to your SV.
http://www.sharpc.com
Username: Lomna
Post Number: 117
Nalin... Thanks for your help,but really wondering why it is doing only on sat 148.Deleting channles from other sats I have no problem with. By the way what channel master gonna do ?
Username: Nydas
Post Number: 7944
You have all you scanned and edited channels in your receiver as you want it with your favourites set up you parental lock in place, etc.
You load it into your channel master and save it as a file. You can edit it as much as you like, including change of name, change of any other sections etc and save it.
You then load your latest BIN, load the channel list into your receiver after it and you are almost completely set for vieing except for Dat/time in some receivers.
In your situation, you will be deleting all the unwanted channels in your computer under channel master and not on your receiver where you are experiencing freezing.
Download it and install. It is a free download from
Username: Lomna
Post Number: 119
Nalin Thank you very much....
