HELP, URGENT my viewsat ultra has green lite syndrom, what do I do?
Username: Ubba
Post Number: 72
I don't know how to jtag or anything. I tried to load yesterday's program on my viewsat ultra and it froze on do not power off. It kept like that for the longest time, that I had to power off. And now, I have the green lite syndrom. What do I do? PLEASE ANY HELP IS VERY MUCH APPRECIATED. I don't know how to jtag.
Username: Lol
Post Number: 301
u can't jtag a viewsat
try to load factory file from support section of [link removed]
use your serial cable and loader2 program should take 2 minutes then load latest 3rd party file should take another 2 minutes
Username: Jayson
Post Number: 119
use loader 2 and null cable on your PC.......flash with factory bin then latest bin.......
Username: Jayson
Post Number: 120
Username: Ubba
Post Number: 73
there are so many loaders on viewsat usa, which one do I use and where do I find the factory bin, is it the Viewsat ultra one, then I add the latest bin?
Username: Jayson
Post Number: 121
loader 2.......ultra factory bin then latest bin.......
Username: Ubba
Post Number: 74
I did it and bless you guys, it worked. The only thing is now the channels are autorolling. So, I reloaded by usb the latest bin and am doing a blind scan, hopefully that will make the channels work. I will let you know what happens. I appreciate your help so much. Thank you again.
Username: Lol
Post Number: 302
do not blind scan bah bah not good bah shame on you
do auto scan
Username: Jayson
Post Number: 122
lisa, you didn't have to scan again........if you let it autoroll for 5 to 10 minutes channels will come back......it usually happens after installing new bin.........
Username: Nydas
Post Number: 7899
Viewsats BINs take substantially longer time to roll in.
Username: Palau
Hercules, Coahuila Mexico
Post Number: 13
Hi There!
Just bought my VS ultra. What`s the new bin and what`s the procedure to load it? Is it like the Lava 3200 I was using? What are the specs? Please help!!!
Username: Cartier1
Post Number: 1750
lisa may sure of your configuartion. make sure you have autoroll on .
Username: Nydas
Post Number: 7925
Alfredo Santos Gonzalez : Get a USB drive and download the latest bIN from
[link removed]
[link removed]
Unzip the BIN and load it into your Viewsat with your remote. Press Menu on your Receiver and you will see what to do.
