Silver Member Username: LuciaCalgary, AB Post Number: 526 Registered: May-06 | My remote is not working.. what do i do? |
Gold Member Username: RtapFL Post Number: 1800 Registered: Jan-07 | many are reporting the same problem |
Silver Member Username: LuciaCalgary, AB Post Number: 528 Registered: May-06 | also... i put the right bin (Pansat remote fix) |
Gold Member Username: RtapFL Post Number: 1801 Registered: Jan-07 | reload bin again.try this |
Gold Member Username: NydasPost Number: 7894 Registered: Jun-06 | Lucia: Your remote might be a 2700 remote. 1. Try removing batteries from the remote and putting them back in. 2. Try switching between P and F at the bottom of receiver if they are there. 3.Try using the jvvh BINs. According to the jvvh_248 instructions: "Pansat 2700 remote users still use the Jvvh_PansatRemote_248 bin. Pansat 2500 / Fortec / Pantec Remote users will have to use the Jvvh_FortecRemote_248 bin." The CS_248T_lightning is working fine. All three BINs available separately from http://public.box.net/2500_full_kit |
Silver Member Username: LuciaCalgary, AB Post Number: 529 Registered: May-06 | ok. thanks, i'll try it right now. |
Silver Member Username: LuciaCalgary, AB Post Number: 530 Registered: May-06 | nalin i used the bins from your kit. but ill try thaT right now |
Silver Member Username: LuciaCalgary, AB Post Number: 531 Registered: May-06 | still is not working. |
Silver Member Username: LuciaCalgary, AB Post Number: 533 Registered: May-06 | nvm is working now, with the lighting bin. |
Gold Member Username: NydasPost Number: 7900 Registered: Jun-06 | Install CS_242T or CS_245T. Make sure you attach to your TV and see your remote working. The try CS_248T. I am testing 248T right now - instead of going from jvvh file to CS file I first loaded CS_242 and then the CS_248. I am very comfortable with uploading BINs. If you are too, I suggest loading jvvh_208_2500to2700.bin or j27_205_1.bin and then loading the CS_245 - CS_248 All the files are there in the KIT. Once on somebody else's receiver I had to do a "Revert to 2500" and then start all over again and it worked. I find that the conversion system is immune from user inflicted punishment. It usually springs back to life. |
Silver Member Username: LuciaCalgary, AB Post Number: 536 Registered: May-06 | thank you nalin, i loaded the Lighting bin from ftabins.net and its working fine now. thanks tho. |
Silver Member Username: Jwl1Post Number: 109 Registered: May-06 | downland jvvh 248 [link removed] DN and Bell 100% up This was posted by Error (user name). It works great. |
New member Username: HtranPost Number: 5 Registered: Jan-08 | Fixed remote problem with CS_248T. Had remote problem since 3 weeks ago. Now working awsome with this new bin. Thanks a lot Nalin. |
Silver Member Username: AdavePost Number: 119 Registered: Jun-06 | remote work with 248T |
Silver Member Username: PsychmonsterRhodium MemberAint nuthin ... Post Number: 689 Registered: Jul-06 | if you need remote in emergency, pick up the 3500 all in one on ebay...cheap and mostly works with conv except numbers for some strange reason |
