Bronze Member Username: Parmar37Post Number: 15 Registered: Oct-06 | every time i have to load a new bin i have to go to a local college library to do it. i don't have a 9 pin serial port on my pc, i do have a VGA HD15F port, my question is can i use MULTISYNC VGA HD15F to DB9M ADAPTER to load the bins |
Gold Member Username: Saqeeb9000Post Number: 1915 Registered: Oct-07 | I TRIED IT SOME USB TO SERIAL PORT.. DIDN'T WORK FOR ME...BUY SOME THING LIKE SONICVIEW 4000 OR VIEWSAT ULTRA.. |
Silver Member Username: DrmunnaPost Number: 276 Registered: Oct-07 | U CAN TRY THAT I GUESS... wont harm anyway what receiver u got?? |
Bronze Member Username: Parmar37Post Number: 16 Registered: Oct-06 | pansat 2700a |
Silver Member Username: DrmunnaPost Number: 277 Registered: Oct-07 | Have u tried usb to rs232? |
Silver Member Username: ExtremexPost Number: 162 Registered: Nov-07 | sanjay, No way that will work. You need a USB to RS232 Adapter. |
Bronze Member Username: Parmar37Post Number: 17 Registered: Oct-06 | yep, in fact i have tried two different types of usb to serial cables none worked for me. |
Silver Member Username: DrmunnaPost Number: 278 Registered: Oct-07 | when i had ariza always used to work i mean usb-rs232 donnot why doesn't work for u i dont no about 2700 but it should work |
Silver Member Username: Albino_midgetPost Number: 671 Registered: Jul-06 | null cable must be used with the usb to serial cable |
Bronze Member Username: Parmar37Post Number: 18 Registered: Oct-06 | so you guys are saying that i will have to use a usb to serial cable and that is my only option |
Gold Member Username: NydasPost Number: 7773 Registered: Jun-06 | sanjay: There is a search feature on this site. If you attempted to do a search on this topic you would find about 50 posts in the last month. **---**---**---**---**---**---**---**---**---**--- https://www.ecoustics.com/electronics/forum/home-video/441271.html Posted on Wednesday, January 30, 2008 - 10:30 am: My Post Number: 7754 |
Bronze Member Username: Parmar37Post Number: 19 Registered: Oct-06 | my main question is still will a MULTISYNC VGA HD15F to DB9M ADAPTER seen below work on loading new bins on my pansat 2700a |
Bronze Member Username: BernardmiPost Number: 63 Registered: Dec-07 | Sanjay. If you use the adapter HD15F to DB9M you will blow up your computer AND satellite receiver. Is that clear ? Do NOT repeat NOT use the adapter. Go and buy a real good USB to RS232 converter. One that works 100% sure is the I/O Gear USB to Serial/PDA Converter Cable (GUC232A) I have tested it with Win98, Win 2000, XP and Media Center It works correctly. |
Gold Member Username: Cartier1Post Number: 1731 Registered: Feb-07 | sanjay you should try being shoe maker . being a shoe maker will give some logic. do u fu*ck any holle you find or it has to be a pu*ssy ? |
Gold Member Username: DoreenakadjOntario Canada Post Number: 1085 Registered: Dec-06 | You could try to buy an usb docking center for your PC... I have a desktop PC with a usb laptop docking center (targus) is the name. It has all the usb and serial ports... lan , printer etc... I have a HP PC that didn't have a serial port so I originally bought it for my HP PC but it works for my clone(self made) PC too. OH and cartier stfu |
