Hi, I have a viewsat ultra and I am not getting any channels, Antenna setup is good, basically it has locked Echo*7, Echo*8 and 10 and Echo* 5, but not should what should be LNBType?
you might consider to upload the factory file and flash the lastest bin file for the Ultra again to see that work better. I got some problems like that before and it worked
it happened sometimes, I am experiencing lost quality on some channels sometimes right now with the latest bin, but if I switch off from the back and reboot, everything is back ok. just bit lazy to reload the bins, ecm gonna hit very soon anyway, will fix that till then.
