How to program flu thats been converted to pansat
Username: Sam2256
i know you use blacklist 1.4 and the cs or cvvh bin whats the proceedure in which you load it . any help would be grately appreciated.
Username: Nydas
Post Number: 7760
If you are serious, read and follow the instructions properly. There are no short cuts.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest CS_245T_Lightning files for DN and BEV fix.
The latest jvvh_244 files for Pansat or Fortec remote '" for DN and BEV fix.
The 244 and 245 version conversion files are available separately as well
Some jtag files are also included.
The full kit is in full_kit14C.zip. Unzip into a new jvvh directory. and read the instructions in the Instructions.doc file.
http://public.box.net/2500_full_kit
